No SID in clearance, fly it anyway?
Old November 7th 03, 02:05 AM
Ron Rosenfeld
On Thu, 06 Nov 2003 14:57:50 -0800, wrote:
It is? Sounds like one, or perhaps both of us, is confused.
I understood you to say that a VFR airport wouldn't have an OPD. True enough. But, many IFR
airports don't have ODPs either. So, the existence of absense of an OPD is not the real clue;
takeoff minimums or lack thereof is the more important clue.
My role in this discussion has been to point out that ODP's are safe, and
that ATC must protect the ODP routing for any IFR departure.
In that context, your responses, although accurate, did not relate in my
opinion.
RR: If you fly an ODP, you will have terrain separation.
AP: Assuming it's an IFR airport. If not, then the airspace has not been
evaluated for takeoff minimums and 40:1 surfaces.
RR: Nor would there be an ODP to fly
etc.
Your statement is related to the more general problem of departing in IMC,
but not related to the point that ODP's will provide terrain separation and
should be protected by ATC. ODP's are not the only method of safely
departing an airport in IMC. The method a pilot chooses to use depends on
many variables, including whether or not there is a SIAP; weather; climb
rate of his a/c; rules under which he is flying; company policies; etc.
I don't disagree with anything you've written. And if you had not written
it apparently in response to my statement that flying an ODP provides
terrain separation, we would not even be having this discussion g.
GPS approaches with Center Dan Luke Instrument Flight Rules 104 October 22nd 03 09:42 PM
IFR Routing Toronto to Windsor (CYTZ - CYQG) Rob Pesan Instrument Flight Rules 5 October 7th 03 01:50 PM
required readback on clearance [email protected] Instrument Flight Rules 15 September 17th 03 04:33 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 12:40 AM
