David Megginson wrote in message ...
(Nathan Young) writes: Your statements that the GPS lags dangerously are inaccurate (at least wrt to the Garmin 295). The HSI updates quick enough to show heading changes of a few degrees as long as the bank angle is kept under a reasonable amount, say 10 degrees. Easy to do in smooth or light turbulence. The lag is time, not heading. How long does it take a heading change to register? I've heard that it's at least a second on the 196, and sometimes two seconds or more on the 295, but I don't own either. It is probably a 1 or 2 sec update rate. That is often enough to detect and display heading changes of a degree or two (as long as bank angle is kept reasonable). The 'lag' is roughly equivalent to the update rate. Ie, the GPS updates every second, and is showing you position, heading, velocity derived from the t and t-1 epoch. Most GPS engines are running faster than the display rate. GPS engines from 5-10 years ago operated on 1 or 2 sec position updates. Newer engines are more granular, with 5Hz operation being common. That means the display data shown is typically derived from the velocity/heading calculated from the time 1 and 1.2 seconds in the past. -Nathan |
David Megginson wrote:
The reason I'm skeptical is that the mag compass also works fine for holding heading in smooth air with very shallow turns: it doesn't go to hell in a handbasket until the air gets rough, precisely the same time the update lag in a handheld GPS could potentially also make it difficult to use. That's why I'm interested in hearing from people who've used it successfully in rough air, preferably at night (where there are fewer visual cues like shadows moving over the panel). And that's why I'm looking for a device that acts - effectively - as a backup AI. I saw a couple of devices at the Expo. Both were "boxes" that plugged into different "computers". One was a large box that plugged into what I think was and Ipaq, and one was a small box that plugged into a "Cheeta" portable MFD device. I really liked the Cheeta, but I think it was the most expensive of the solutions I saw. Anyone have other thoughts about this? What was the price of a panel-mounted electric AI? 4K? I wonder if I could get the club to consider such an investment on our aircraft. - Andrew |
Nathan Young wrote:
Most GPS engines are running faster than the display rate. GPS engines from 5-10 years ago operated on 1 or 2 sec position updates. Newer engines are more granular, with 5Hz operation being common. That means the display data shown is typically derived from the velocity/heading calculated from the time 1 and 1.2 seconds in the past. What units have a 5Hz update? The only one I am aware of is the CNX80. I don't know of any others better than 1 Hz... oh, maybe you meant 5 Hz intenally, with a 1 Hz update of the display? Dave Remove SHIRT to reply directly. |
![]() Dave Butler wrote: Nathan Young wrote: Most GPS engines are running faster than the display rate. GPS engines from 5-10 years ago operated on 1 or 2 sec position updates. Newer engines are more granular, with 5Hz operation being common. That means the display data shown is typically derived from the velocity/heading calculated from the time 1 and 1.2 seconds in the past. What units have a 5Hz update? The only one I am aware of is the CNX80. I don't know of any others better than 1 Hz... oh, maybe you meant 5 Hz intenally, with a 1 Hz update of the display? Oh, never mind. That's what you *said*. Sorry for the noise. Dave |
I wonder if Chris Thomas is a real pilot? Anybody know? | Badwater Bill | Home Built | 116 | September 3rd 04 05:43 PM |
Pilot Error? Is it Mr. Damron? | Badwater Bill | Home Built | 3 | June 23rd 04 04:05 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
Effect of Light Sport on General Aviation | Gilan | Home Built | 17 | September 24th 03 06:11 AM |
