![]() "Peter R." wrote in message ... Gig 601XL Builder wr.giacona@coxDOTnet wrote: I think you really know what I meant and are just being argumentative. Eh? I disagreed with your comment about the three hour checkout and provided the reasons for my disagreement. You now dismiss all of this as argumentative and hide behind the excuse that I knew what you meant all along, as if I am some type of mind reader? That's just silly. Ok. sorry but the vast majority of flying Skyhawks are not the newer SPs but the older "plain old Skyhawks." If you look again at my first post in this thread, it only asked what model to which you were referring. You are welcome to quote the words from my post that you interpreted as argumentative. Need I remind you that in your follow-up, it was you who lobbed a personal barb by questioning how many hours it took me to solo, as if you expected this to demonstrate some level of incompetence. That was a joke. You had made a comment that the Carb heat issue would take 3 to 5 hours of check flight time to learn. If that is the case for you and as I said I didn't think would then the learing to fly the whole plane would be on the order of 3 or 4 hundred hours. Like Newp so perfectly put it. "Pull out the carb heat below the green arc. Push it in aboove the green arc. There. You're checked out." |
That was a joke. From the Steven P. McNicoll school of comedy, no doubt. You had made a comment that the Carb heat issue would take 3 to 5 hours of check flight time to learn. Well, at least get the quote correct. For the record, I stated the following: "I have about 450 hours in a C172SP and I would probably need a couple of hours of instruction/flying just to become familiar with carb heat usage if I hypothetically needed to rent an older C172 model." "Probably need a couple hours" is not three to five hours, at least in my book. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Ok. sorry but the vast majority of flying Skyhawks are not the newer SPs but the older "plain old Skyhawks." Well, Gig, I have to thank you. Your statement above was screaming for a reference to back it up but instead of putting the burden on you, I decided to try to prove or disprove it myself. Therefore, I visited the FAA website and discovered that the FAA registered aircraft database is offered there as a free, downloadable zip file. Without a database management tool on my PC, I then downloaded the Open Source database product called MySQL. Fortunately for me, there was a Windows install routine that made installation and configuration rather painless. I then created a couple of tables and imported the aircraft reference data and the master registration data from the FAA zip file (data current as of August 5th, 2005). The end result? I was able to query the two tables to see exactly how many C172s manufactured from 1997 onward are registered compared to the number of C172s manufactured prior to 1996. Note that it appears that 1986 was the year Cessna ceased production of C172s until the GA Revitalization Act, but for some reason there are three aircraft in the database with a 1988 MFG date and 1 with a 1994 date (perhaps this was a test A/C?). Of course, there is the legitimate argument that not all aircraft registered are actively flown. Logic suggests that this would be more applicable to older aircraft than newer, so the pre-1996 numbers could be lowered by some degree. Here are the results: Number of C172s registered, pre- and post-General Aviation Revitalization Act (C172s produced from 1997 onward are all the modern, fuel-injected, more advanced avionics models we have been discussing): 1997 onward - 2,305 1986 and prior - 24,251 So, about 91% of all registered C172s are pre-1996. I suppose that qualifies as a vast majority. ![]() -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() "Peter R." wrote in message ... Gig 601XL Builder wr.giacona@coxDOTnet wrote: Ok. sorry but the vast majority of flying Skyhawks are not the newer SPs but the older "plain old Skyhawks." Well, Gig, I have to thank you. Your statement above was screaming for a reference to back it up but instead of putting the burden on you, I decided to try to prove or disprove it myself. So, about 91% of all registered C172s are pre-1996. I suppose that qualifies as a vast majority. ![]() Good researching Peter. 10:1 Sounds about right. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
