![]() "David Koehler" wrote in message ... Hi All, I'm not there yet, but, I have a new Lycoming O-360 and in the process of building a homebuilt kit. Lycoming says to break in the engine at full power and gives procedures on how to do it. The kit needs slow taxi, then fast taxi, glazing of the brakes. After take off there are procedures to do at lower power.... I know I'm not the FIRST in this dilemma, so what takes a preference? If you wait to do the full power to seat the rings, is that ok? Thanks for any response, I'm at a loss, david The brake break-in procedure only requires a few minutes of taxi time and a couple of stops, IIRC. On my RV-6 (I assembled the airplane rebuilt the engine myself), I probably ran the engine 10-15 minutes before the first flight. First was a short run to make sure it ran and didn't have major leaks. Then was a short run to taxi the airplane the length of the taxiway, performing the pad break-in procedure. The third time I cranked the engine, I taxied to the end of the field, ran up the engine, and launched into the blue. Of course, I had done LOTS of work to verify that all of the controls had good continuity and the aircraft was properly rigged. I've known too many people who had trouble due to sloppy rigging on the first flight. It is attention grabbing to make the first flight of any homebuilt aircraft, moreso one where you built the engine too... KB |
![]() "Kyle Boatright" wrote It is attention grabbing to make the first flight of any homebuilt aircraft, moreso one where you built the engine too... Moreso? Don't they make racing engines, or something? vbg -- Jim in NC |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
V-8 powered Seabee | Corky Scott | Home Built | 212 | October 2nd 04 11:45 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
