![]() MaD wrote: I don't get it: Why on earth do so many people pull up and do a circuit? Because this gives me the opportunity to switch from "final glide" mode to "landing mode" at a low airspeed. I can't imagine opening my dive brakes at 140 knots! There must be a difference in the US and the IGC definition of the finish gate/line. Can someone explain? Why is it not normal (at least judging from what I read here it isn't in the US) to land straight in after the finishline? At most competitions with a line, it is located near the middle of the airport. A pilot is expected to cross it above 50', then land. If below 50', then the pilot must have announced a rolling finish and may roll or fly through, but be in a "slow" landing configuration. I use an arrival height of 700' in my glide computer. So if all is perfect, I would cross the airport at this altitude at a normal interthermal cruise speed. If I hit sink within a mile or so of the line, I still have the margin to cross either high enough to make a circuit or do a straight in. If I hit lift, then I speed up and as I get within a mile or so, I ignore the computer and use my eyeballs as I push to as fast as I consider safe for the conditions. But I plan on entering the downwind leg at no less than about 400' and continually reasess the situation as I fly the last couple of miles. In a paper by John Cochrane (Safer Finishes) there's a list of accidents. More than half of them have nothing to do with the finishing procedure. They could have happened just the same with any other procedure, some even without a contest, some did'nt even happen at the airfield. All the others (6) are the pullup-stall-spin type. So again: why pull up? Because the pull up is done from a high speed I built up after determining the altitude margin I had was good enough to make the dive and pull up. This cuts a few seconds off my time - once I've realized it is safe to do so. The accidents happen when the pilot is only thinking of crossing the line and not planning ahead and makes the dive with not enough energy. I have the option to fly a constant speed and arrive at 6-700' over midfield, or to dive at the line, then pull up and agin be at 6-700' on my downwind entry. You propose I aim for the end of the runway and arrive with near zero altitude and "some" energy. I don't like this as it puts me too low and too slow over potentially unlandable terrain. I then am forced to land straight ahead without the opportunity to get a good look at the landing area. I also must put down the wheel, lower flaps and extend the airbrakes while putting more and more runway behind me. I like to fly a final approach with full flaps and nearly full spoilers, with a plan to land somewhere convenient in the first 50% of the runway. If an obstacle appears suddenly, I can close spoilers, then flaps and float past, then set up another approach as far down the runway as is safe. Or make an S turn to an adjacent landing area. After flying dozens of finishes at international comps and many more in various versions at national and regional comps I am absolutely convinced that a finishline at ground level at the beginning of the runway and then landing straight ahead is the safest method, especially when many competitors arrive at the same time. I'd hate to be in a situation with ten or more gliders all on circuit at the same time not knowing who's going to turn when and where because everybody has his own idea of where the pattern is. At all competitions I have flown, the organizer or gatekeeper suggests a pattern direction and everyone finishes, then pulls up to pattern speed and flies the downwind leg (if possible). At this time, the higher glider may orbit to let the lower one go ahead, or may extend the downwind leg, etc. Some traffic marshalling occurs in the final glide, but most of it occurs on the downwind leg while everyone is operating at a nice leisurely pace compared to the fast final glide. I have landed behind 8-10 or more sailplanes in this way without any problem. We were all separated by about a towrope length while abeam the midfield, all the way to final approach. No problems! Had we been doing a straight in approach, the gliders would all be flying different speeds over the threshold and the one behind would have no way to judge the energy carried by the one in front. I have also participated in dozens of competitions over the 30+ years I have been soaring and all of the unsafe finish operations I have seen involved a single pilot not showing good planning or judgement. I can't think of any cases where multiple sailplanes were involved in a (potential) incident, one always was able to take necessary action to avoid the errant pilot and the possibility of a collision was averted with plenty of time and room left over. (If you aren't constantly averting a collision in a thermal, then I don't want to be anywhere near you!) I'm not trying to cop out with the "pilot error" excuse here, but it really is a strong factor. So far most other suggestions for the contest finish just move the error zone to a different location, but do not eliminate or even reduce it. In another post it was mentioned that Mr Knauff thinks we ALL need to learn how to fly better, and I agree. We should strive to make every approach and landing be perfect at all phases. We should strive to make our flying be predictable, so the ones around us can anticipate our next move. Then, it won't matter if the pattern entry was made from 10' and redline or 1000' and minimum sink speed. After a couple days at a contest, I know which pilots I can trust - too bad I can't trust everyone! Consider the 2-lane highway. Cars pass head on at closing speeds approaching 150 mph at a distance of less than 10'. It works very well until some impaired person screws it all up. And if you'd show this to a remote jungle dweller, he would think we were nuts. -Tom ASH-26E 5Z |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
US Region 7 Soaring Contest | Paul Remde | Soaring | 0 | May 11th 05 03:19 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
30th Annual CCSC Soaring Contest | Mario Crosina | Soaring | 0 | March 17th 04 06:31 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
