There are ADs against many mags, some of them dealing with
impulse failures. Get the mechanic to check for any that apply to this mag. Corrosion and sludging often cause sticky impulse couplings. Neither are good, especially the corrosion, which can cause spring breakage and power loss. Mags on infrequently-flown airplanes, or those mags that haven't been off for a long time, definitely need checking. Dan Dan |
impulse failures. Get the mechanic to check for any that apply to this mag. Corrosion and sludging often cause sticky impulse couplings. Neither are good, especially the corrosion, which can cause spring breakage and power loss. Mags on infrequently-flown airplanes, or those mags that haven't been off for a long time, definitely need checking. Dan All the AD's are complied with. I use Aeroshell 15W - 50 semi-synthetic oil, changed every 50 hours and will be surprised if things are gunked up or corroded but I might get shocked. I put over 100 hours on the Cherokee this year including the 2000 nm cross country trip to Canada and back. I've averaged somewhere between 80 to 120 hours per year on her for the 7 years I've owned her and have installed rebuilt mags once. We are going to pull the mag in question and take a closer look. Thanks for confirming what my conscience was already subtly telling me to do. ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
