![]() "Dave S" wrote in message nk.net... Go missed. Climb and re-establish radio contact. Re-do the approach and while still in contact with approach, request a contact approach.. or cancel IFR and request a special VFR clearance. Roy said there's no weather reporting at this location. That rules out a contact approach and SVFR. |
In article et,
"Steven P. McNicoll" wrote: "Dave S" wrote in message nk.net... Go missed. Climb and re-establish radio contact. Re-do the approach and while still in contact with approach, request a contact approach.. or cancel IFR and request a special VFR clearance. Roy said there's no weather reporting at this location. That rules out a contact approach and SVFR. Yes, I know both the Contact and SVFR were unavailable. On the other hand, people were flying around VFR. I know my original statement of "assume it's 2-1/2 miles where you are" eliminated VFR from the list of legal alternatives, but for all I know, it really was 3 or 4 miles. I could have gone missed, gotten back in contact with ATC, cancelled IFR, and then proceeded back to the airport VFR. But that seems totally pointless. What if I hadn't asked you to assume it was 2-1/2 miles? The rest stays the same, ATIS at several airports in the area reporting variously 2-1/2, 3, and 4 miles. Lacking an official report, the best I can say is "an honest evaluation of flight visibility by the pilot could have reasonably been said to be 3 miles". |
![]() "Roy Smith" wrote in message ... Yes, I know both the Contact and SVFR were unavailable. On the other hand, people were flying around VFR. I know my original statement of "assume it's 2-1/2 miles where you are" eliminated VFR from the list of legal alternatives, but for all I know, it really was 3 or 4 miles. I could have gone missed, gotten back in contact with ATC, cancelled IFR, and then proceeded back to the airport VFR. But that seems totally pointless. What if I hadn't asked you to assume it was 2-1/2 miles? The rest stays the same, ATIS at several airports in the area reporting variously 2-1/2, 3, and 4 miles. Lacking an official report, the best I can say is "an honest evaluation of flight visibility by the pilot could have reasonably been said to be 3 miles". Are you asking what's legal or what's wise? Assuming the former, as long as you have at least three miles visibility and remain at least 500 feet below, 1000 feet above, and 2000 feet lateral clearance from all clouds I'd say you can legally land. FAR 91.175 would no longer apply as you're no longer operating under IFR. |
Are you asking what's legal or what's wise? Neither. I'm asking what other people would do. |
I don't beleive weather reporting is a requirement for Special VFR per
FAR 91.157. |
![]() "gman" wrote in message oups.com... I don't beleive weather reporting is a requirement for Special VFR per FAR 91.157. Special VFR exists only in a surface area, weather reporting is a requirement for a surface area. |
Steven,
Could you point me to correct FAR paragraph? A quick search of the part 91 FARs on AOPA's website did not turn up anything supporting your statement. Thanks |
![]() "gman" wrote in message oups.com... Steven, Could you point me to correct FAR paragraph? A quick search of the part 91 FARs on AOPA's website did not turn up anything supporting your statement. Which statement? That Special VFR exists only in a surface area or that weather reporting is a requirement for a surface area? |
For both.
![]() "gman" wrote in message ups.com... For both. FAR 91.155(c) states, " Except as provided in §91.157, no person may operate an aircraft beneath the ceiling under VFR within the lateral boundaries of controlled airspace designated to the surface for an airport when the ceiling is less than 1,000 feet." That refers to a surface area. From the Pilot/Controller Glossary: SURFACE AREA- The airspace contained by the lateral boundary of the Class B, C, D, or E airspace designated for an airport that begins at the surface and extends upward. The procedures for establishing surface areas are found in FAA Order 7400.2, "Procedures for Handling Airspace Matters". There are two requirements that must be met prior to establishing a surface area: 1.) Communications capability with aircraft must exist down to the runway surface of the primary airport either directly with ATC or by rapid relay through another communications facility which is acceptable to ATC, such as a FSS. 2.) Weather observations must be taken at the primary airport during the time of designation of the surface area. |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 05:34 PM |
Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 04:32 AM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
