wrote in message ...
Gary Drescher wrote: wrote in message ... The reason I ask about the phone is because you could have opted to cancel IFR and then do whatever you wanted to do to get in and land. In the absence of radio or phone contact, can you unilaterally cancel IFR and inform ATC after you land? --Gary For non-commercial operations I don't see why not. But, it's not clean and someone may say it was wrong to hold the airspace when you had "cancelled" as a state of mind. But if the alternative were to not cancel at all, then the airspace would be just as held-up. Or, some might argue that a cancellation does not take effect until ATC acknowledges its receipt. Yup, that's what I'm unsure about. Also, if you did cancel unilaterally, would you then squawk 1200 in case ATC still had radar contact? --Gary |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 05:34 PM |
Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 04:32 AM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
