"...but I don't have a lathe."
Old August 18th 05, 02:34 PM
dodger
It is indeed the same screw, but the mating surfaces of the chuck are
not perfect and tightening only one hole will cause some off centering.
Tightening all three holes reduces any such tendency. Ask any machinist
they will tell you "tighten at all holes".
Old August 18th 05, 07:25 PM
LCT Paintball
I've been a Tool and Die maker for over 20 years and I disagree with your
statement. A drill chuck isn't meant to be accurate, nor is it meant to be a
three jaw lathe chuck. I'm not saying you can't do some cheating here and
there, but expect the accuracy of your equipment to take a beating. I do
understand that you can't always have the perfect tool for every job that
needs to be done, but you gotta be careful when you improvise. Remember, a
drill press isn't designed to take side loads, and neither is a drill chuck.
With that being said, I'll admit that before I bought my first CNC lathe, I
used one of my CNC mills as a lathe to make simple plastic parts.
Perhaps the difference is the quality of my equipment. The drill chucks I
use are completely rebuildable, and cost almost as much as some people spend
on their whole drill press. Perhaps that's why I've never had an accuracy
issue when tightening only one hole. Or, maybe it's because if I really need
it to be accurate, I use collets instead.
I think your ideas are very reasonable if the craftsman doesn't get in a
hurry and chooses his cutting tools carefully. Avoid clamping things to the
table, and feeding in with cross slides if you have that capability. As long
as you're using hand held tools, it would be difficult to overload your
bearings, and with your mounting idea, you'll be less likely to have the
part go flying across your shop. Especially if you back up the end of the
part like you suggested.
Old August 19th 05, 04:53 AM
Ernest Christley
Mr. Paintball, I think the giveaway was when Veedubber mentioned "cheap
chinese drillpress". In my mind this is one of the $30 Harbor Freight
models. It takes about two of those to complete a Dyke Delta. (the
first one wears out halfway through). Combining precision in the same
sentence with one of these is a great injustice to the english language.
Now not every piece on an airplane requires millionth of an inch
accuracy. Will an airplane crash if the plug used to make lightening
holes is slightly oblong?
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Why is Soaring declining f.blair Soaring 266 February 7th 09 12:58 PM
Antique ex-freon now used as air compressor seen this type? Jason D. Home Built 12 November 17th 04 03:07 PM
Non-Flying Ladders Veeduber Home Built 5 July 10th 04 05:15 AM
Lathe Help Bruce A. Frank Home Built 15 February 7th 04 09:05 AM
