George Patterson wrote:
: Anyway. If you get a fabric aircraft that has a Ceconite or Polyfiber skin with : polyurethane applied over a dope base coat, you shouldn't have problems with : the fabric. : Corrosion is a different issue, but metal aircraft also have problems with this. Just out of curiosity, if one were to learn the art of recovering so as to do it oneself, what would a reasonable expense be to recover a bird like that? It seems that so long as you know how to work on it, fabric planes aren't a big deal. In a lot of ways, they're better than metal, since you can reasonable take the lid off and look inside for corrosion. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
: I spoke with a fellow who redid his Champ. IIRC, his cost was a bit over $2,000. : A lot depends on whether you use bolts of fabric and glue the stuff directly to : the frame or buy pre-sewn envelopes. Maule glues the fabric onto the frame. : Maule Flight will charge you $12,000 for a strip and recover. ... but then it must be painted as well, right Depending on how much of *that* you do yourself, it could cost considerably more than the recovering. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Maule Flight will charge you $12,000 for a strip and recover. Is that without paint? By the way, I have a '96 "we have them on sale" MX7180a model (actually built in '95). Not the good paint (still doing it against the hangar wall). Not the really bad (auto)paint. IOTW, it chips off slowly. I love the damn thing if only I had the good paint |
Maule Driver wrote:
Is that without paint? That's the whole job, paint and all. I got that price from Rautgunde several years ago, though. It may have gone up. They also had a price of ~$15,000 for a complete renovation. By the way, I have a '96 "we have them on sale" MX7180a model (actually built in '95). Not the good paint (still doing it against the hangar wall). Not the really bad (auto)paint. IOTW, it chips off slowly. If I'd bought the 180, I might still have mine. On the other hand, the loan would've been larger and I might have lost it all. I found out what the paint scheme was from a Randolph representative at Oshkosh several years ago. He said that Maule used the Ceconite process, which specifies a coat of nitrate dope, followed by silver butyrate. He said they would add a coat of white butyrate over the silver as a primer and then spray the enamel over that. He said it was possible to sand off the color coats (the enamel) down to the white dope primer or even down to the silver. Don't go into the silver coat at all -- if you see it, stop. Once you get the enamel off of the fabric, spray with butyrate rejuvenator. After that, you can apply either polyurethane or butyrate top coats. If you're plane is like mine was when I sold it, you can see patches of the white butyrate where the color coats have flaked off of the horizontal stabilizer. We did not discuss redoing the paint on the metal or fiberglass sections (unless maybe he was recommending that technique for those sections too). I know that the upper surfaces of my wings were badly peeled by the time I sold it, so something would have to be done there. Since chemical paint strippers will melt Ceconite in a heartbeat, I would consider something like bead-blasting. Randolph made the paints Maule was using back then. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
That's what I seem to have. I bought some Randolph paint to touch-up
but never did. I have chipping on the stab as you described. Wings are fine except for fairings. In fact, every surface facing the prop blast as been chipped to primer due to flying in the rain. Oh well. I would love to get it redone. With 900 to go to TBO, I'll probably fly it out while doing some homebuilding. Except for the chipping paint, it's been a (cheap) joy. Simplicity is good. BTW, I didn't buy new - 3rd owner at 35 hours. Thanks! George Patterson wrote: I found out what the paint scheme was from a Randolph representative at Oshkosh several years ago. He said that Maule used the Ceconite process, which specifies a coat of nitrate dope, followed by silver butyrate. He said they would add a coat of white butyrate over the silver as a primer and then spray the enamel over that. He said it was possible to sand off the color coats (the enamel) down to the white dope primer or even down to the silver. Don't go into the silver coat at all -- if you see it, stop. Once you get the enamel off of the fabric, spray with butyrate rejuvenator. After that, you can apply either polyurethane or butyrate top coats. If you're plane is like mine was when I sold it, you can see patches of the white butyrate where the color coats have flaked off of the horizontal stabilizer. Randolph made the paints Maule was using back then. |
Maule Driver wrote:
I would love to get it redone. One thing you might consider is to fly it down to Moultrie for an annual inspection and have the work done at that time. Of course, Maule Flight isn't the cheapest place for an annual, but they do the best work on Maules of any place I know of. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
A question for you "dopers" out there.
I have seen a Citabria fabric aircraft sitting in a shop with the floor covered in big paint pieces that I was told had been stripped by using shop air and a small air nozzle on a blow gun. I had flown the aircraft previously and while it's dope (could be paint?) wasn't great it was flyable. I was told that the surface coat had come off surprisingly easily and the silver primer that was left looked like it would not require much further preperation for paint. I was told it only took a couple of hours. If I remember correctly the wings and control surfaces were removed and finished separately. Is it common to be able to remove paint or dope in this manner? "George Patterson" wrote in message news:9j9Ne.10281$Yb.7100@trndny06... Maule Driver wrote: Is that without paint? That's the whole job, paint and all. I got that price from Rautgunde several years ago, though. It may have gone up. They also had a price of ~$15,000 for a complete renovation. By the way, I have a '96 "we have them on sale" MX7180a model (actually built in '95). Not the good paint (still doing it against the hangar wall). Not the really bad (auto)paint. IOTW, it chips off slowly. If I'd bought the 180, I might still have mine. On the other hand, the loan would've been larger and I might have lost it all. I found out what the paint scheme was from a Randolph representative at Oshkosh several years ago. He said that Maule used the Ceconite process, which specifies a coat of nitrate dope, followed by silver butyrate. He said they would add a coat of white butyrate over the silver as a primer and then spray the enamel over that. He said it was possible to sand off the color coats (the enamel) down to the white dope primer or even down to the silver. Don't go into the silver coat at all -- if you see it, stop. Once you get the enamel off of the fabric, spray with butyrate rejuvenator. After that, you can apply either polyurethane or butyrate top coats. If you're plane is like mine was when I sold it, you can see patches of the white butyrate where the color coats have flaked off of the horizontal stabilizer. We did not discuss redoing the paint on the metal or fiberglass sections (unless maybe he was recommending that technique for those sections too). I know that the upper surfaces of my wings were badly peeled by the time I sold it, so something would have to be done there. Since chemical paint strippers will melt Ceconite in a heartbeat, I would consider something like bead-blasting. Randolph made the paints Maule was using back then. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
private wrote:
Is it common to be able to remove paint or dope in this manner? The Randolph paint rep to whom I spoke said that it is not unusual for an enamel top-coat to peel off of dope this way; in fact, he said I might try using a pressure washer on my Maule to see if I could avoid sanding the enamel off. I've never seen dope top-coats separate from dope undercoats, but perhaps it's possible if the undercoat was not prepared properly. I do not know how well polyurethane bonds to dope. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
George Jr sent out of Texas by father as a 'drunken liability' | WalterM140 | Military Aviation | 17 | September 9th 04 05:26 AM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Texas Soars into Aviation History | A | Piloting | 7 | December 17th 03 02:09 AM |
Bob Wander at Marfa, Texas | Burt Compton | Soaring | 0 | September 16th 03 02:59 PM |
good book about prisoners of war | Jim Atkins | Military Aviation | 16 | August 1st 03 10:18 AM |
