![]() "gman" wrote in message oups.com... Steven, Could you point me to correct FAR paragraph? A quick search of the part 91 FARs on AOPA's website did not turn up anything supporting your statement. Which statement? That Special VFR exists only in a surface area or that weather reporting is a requirement for a surface area? |
For both.
![]() "gman" wrote in message ups.com... For both. FAR 91.155(c) states, " Except as provided in §91.157, no person may operate an aircraft beneath the ceiling under VFR within the lateral boundaries of controlled airspace designated to the surface for an airport when the ceiling is less than 1,000 feet." That refers to a surface area. From the Pilot/Controller Glossary: SURFACE AREA- The airspace contained by the lateral boundary of the Class B, C, D, or E airspace designated for an airport that begins at the surface and extends upward. The procedures for establishing surface areas are found in FAA Order 7400.2, "Procedures for Handling Airspace Matters". There are two requirements that must be met prior to establishing a surface area: 1.) Communications capability with aircraft must exist down to the runway surface of the primary airport either directly with ATC or by rapid relay through another communications facility which is acceptable to ATC, such as a FSS. 2.) Weather observations must be taken at the primary airport during the time of designation of the surface area. |
"Steven P. McNicoll" wrote:
From the Pilot/Controller Glossary: SURFACE AREA- The airspace contained by the lateral boundary of the Class B, C, D, or E airspace designated for an airport that begins at the surface and extends upward. I probably should know this, but now that I (re-)read the above, I see that there's several ways to parse that sentence with respect to B and C airspace: 1) Only the inner cylinder that touches the surface is the surface area, i.e. SVFR is not available in the outer rings of B/C airspace. 2) The boundaries of the surface area are exactly the same (vertical and lateral) as the B/C airspace. This is what I had always assumed. 3) The surface area includes all the airspace from the edge of the outermost ring projected down to the surface. This would be extremely illogical, but it is one possible parsing. Which is correct? Is there such a thing as B, C, or D airspace in the US which is not "designated for an airport"? |
![]() "Roy Smith" wrote in message ... I probably should know this, but now that I (re-)read the above, I see that there's several ways to parse that sentence with respect to B and C airspace: 1) Only the inner cylinder that touches the surface is the surface area, i.e. SVFR is not available in the outer rings of B/C airspace. 2) The boundaries of the surface area are exactly the same (vertical and lateral) as the B/C airspace. This is what I had always assumed. 3) The surface area includes all the airspace from the edge of the outermost ring projected down to the surface. This would be extremely illogical, but it is one possible parsing. Which is correct? Prior to airspace reclassification there were control zones within and distinct from ARSAs and TCAs and SVFR was clearly limited to just the control zone. If SVFR was now available within the entire Class B or Class C airspace it would mean a major change that was not mentioned or discussed during reclassification. FAR 91.155(c) states, "Except as provided in FAR 91.157, no person may operate an aircraft beneath the ceiling under VFR within the lateral boundaries of controlled airspace designated to the surface for an airport when the ceiling is less than 1,000 feet." Since we're only concerned with the portion within 1000 feet of the surface scenario 2) would be eliminated. Is there such a thing as B, C, or D airspace in the US which is not "designated for an airport"? I don't know of any Class B or C like that, but there has been some odd Class D airspace areas. One of them was Pearson Field in Vancouver, WA, about seven miles northeast of Portland International. Pearson had Class D airspace from the surface to the overlying Portland Class C airspace. Vancouver had no control tower and was the only airport in the Class D surface area. Vancouver now has a Class E surface area. Another one is adjacent to the Seattle Class B surface area on the west side. This one still exists, you can view it at the following link: http://makeashorterlink.com/?F27B2314B A third one was south of the El Toro MCAS which is now closed, the Class D airspace apparently was dropped when the base closed. Part of this one didn't even touch the surface. I have old charts which depict this area, I can post some images if you're interested. |
![]() "Steven P. McNicoll" wrote: A third one was south of the El Toro MCAS which is now closed, the Class D airspace apparently was dropped when the base closed. Part of this one didn't even touch the surface. I have old charts which depict this area, I can post some images if you're interested. When El Toro closed KSNA lost half of its Class C airspace because of the way the rules were made piecemeal. It took over a year to get that airspace modified and redesignated to provide the Class C protection for KSNA that used to be there when El Toro was operating. Airspace designations are only as good as the regional airspace staffs responsible for them. |
Steven,
FAR 91.155(c) explicitly refers to "controlled airspace" i.e. airspace classified as E,D,C,B, and A. Since it is possible to be in E airspace without being near an airport, it is possible to operate under Special VFR as long as the requirements in FAR 91.157 are met. Moreover, ground based weather reporting is NOT required for Special VFR and FAR 91.157 (c)(2) explains what to do if "..ground visibility is not reported..". |
![]() "gman" wrote in message oups.com... Steven, FAR 91.155(c) explicitly refers to "controlled airspace" i.e. airspace classified as E,D,C,B, and A. Since it is possible to be in E airspace without being near an airport, it is possible to operate under Special VFR as long as the requirements in FAR 91.157 are met. Yes, it's possible to be in Class E airspace without being near an airport, but I don't think it's possible to be "within the airspace contained by the upward extension of the lateral boundaries of the controlled airspace designated to the surface for an airport" without being near an airport. Do you? Moreover, ground based weather reporting is NOT required for Special VFR and FAR 91.157 (c)(2) explains what to do if "..ground visibility is not reported..". FAR 91.157(c)(1) says no person may take off or land an aircraft (other than a helicopter) under special VFR unless ground visibility is at least 1 statute mile. If ground visibility isn't being reported it's because the AWOS/ASOS is on the fritz or the weather observer overslept. |
I'm sorry for dragging this thing on but part (a) of the paragraph you
quoted (FAR 91.155) says that if the weather conditions (visibility, and cloud clearance) are below the prescribed minimums, you cannot "operate an aircraft under VFR" unless you go Special VFR. The weather minimums in paragraph 91.155(a) only refer to classes of airspace not only to those around an airport. You are correct about FAR 91.155(c,d). However, this rule is in addition to the other parts of section 91.155. Since the original poster was on a GPS approach, and most certainly in controlled airspace, he could have requested a Special VFR clearance and landed as long as he operated clear of clouds and flight visibility was greater than 3SM. Even though the airport does not have an official weather reporting systems, the FARs authorize the pilot to use his/her own judgment in determining visibility. |
![]() "gman" wrote in message oups.com... I'm sorry for dragging this thing on but part (a) of the paragraph you quoted (FAR 91.155) says that if the weather conditions (visibility, and cloud clearance) are below the prescribed minimums, you cannot "operate an aircraft under VFR" unless you go Special VFR. The weather minimums in paragraph 91.155(a) only refer to classes of airspace not only to those around an airport. You are correct about FAR 91.155(c,d). However, this rule is in addition to the other parts of section 91.155. Since the original poster was on a GPS approach, and most certainly in controlled airspace, he could have requested a Special VFR clearance and landed as long as he operated clear of clouds and flight visibility was greater than 3SM. Even though the airport does not have an official weather reporting systems, the FARs authorize the pilot to use his/her own judgment in determining visibility. Since the original poster told us there was no weather reporting at the destination airport we can conclude there is no surface area because weather reporting is required to establish a surface area. Since SVFR exists only in a surface area we can conclude that SVFR was not available even if he had requested it. |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 05:34 PM |
Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 04:32 AM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
