On Thu, 18 Aug 2005 18:50:06 GMT, "Steven P. McNicoll"
wrote: "GeorgeB" wrote in message .. . What would have been the effect if the O2 bottle for the cockpit had been inadvertently filled with breathing air rather than O2? From what would the oxygen system be serviced in your scenario? A compressor? I've far more experience with industrial compressed gasses than with aircraft oxygen, and see much more "compressed breathing air" than BREATHING compressed O2. (Oxygen for oxyacetelyne is to different standards, but I think it is just as good; several college buddies would spend some time breathing it after having too much to drink the night before. Ah, the REAL hangover cure. Firefighters and scuba divers use it in large quantiies. Bottles are common with gas suppliers. What I don't know is how the fittings compare. Nor do I know how a plane's bottles are filled; via compressor from low pressure sources, high pressure via cascade bottles, or ??? I do know that the fittings need to be clean of oxydizable materials; storoes of a little oil on gauge threads, if true, keep one careful. |
"GeorgeB" wrote in
I've far more experience with industrial compressed gasses than with aircraft oxygen, and see much more "compressed breathing air" than BREATHING compressed O2. (Oxygen for oxyacetelyne is to different standards, but I think it is just as good; Correct. It's just as good now. moo |
![]() "GeorgeB" wrote in message ... I've far more experience with industrial compressed gasses than with aircraft oxygen, and see much more "compressed breathing air" than BREATHING compressed O2. (Oxygen for oxyacetelyne is to different standards, but I think it is just as good; several college buddies would spend some time breathing it after having too much to drink the night before. Ah, the REAL hangover cure. Firefighters and scuba divers use it in large quantiies. Bottles are common with gas suppliers. What I don't know is how the fittings compare. Nor do I know how a plane's bottles are filled; via compressor from low pressure sources, high pressure via cascade bottles, or ??? I do know that the fittings need to be clean of oxydizable materials; storoes of a little oil on gauge threads, if true, keep one careful. In a previous life I was in aircraft maintenance. Aviator's breathing oxygen systems were serviced from just two sources; compressed oxygen bottles or liquid oxygen carts. The only other compressed gas bottle used for servicing aircraft was nitrogen. I don't recall what measures were taken to prevent servicing oxygen systems with nitrogen, other than colors and markings on the bottles, but servicing oxygen systems with nitrogen would be a very bad thing. |
would be a very bad thing. What would it feel like to breathe nitrogen instead of oxygen or air? I presume one would just get euphoric, pass out, and die, with nary a clue. Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message ... servicing oxygen systems with nitrogen would be a very bad thing. What would it feel like to breathe nitrogen instead of oxygen or air? I presume one would just get euphoric, pass out, and die, with nary a clue. Jose Years ago we had a contract laborer working in a catalyst vessel with a nitrogen atmosphere. He lifted his breathing air mask to spit. Bad move. Sucked in a breath and it was nearly his last. The man passed out and started convulsing. The confined space attendant radioed for help from the ERT. Ever tried to pull a convulsing patient from a manway? Even with a tripod / winch / cable / harness already rigged, it was quite a job. The man lived but was hospitalized for quite awhile. A co-worker put on an airmask that inadvertently been connected to a nitrogen header. This was back in the 60's. He took one breath and woke up in the hospital. Thankfully, he didn't have a chance to fully strap the mask on. ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Jose opined
servicing oxygen systems with nitrogen would be a very bad thing. What would it feel like to breathe nitrogen instead of oxygen or air? I presume one would just get euphoric, pass out, and die, with nary a clue. Skip the euphoria, and you have your answer. -ash Cthulhu in 2005! Why wait for nature? |
presume one would just get euphoric, pass out, and die, with nary a clue. Skip the euphoria, and you have your answer. Ok, then what causes the euphoria which is supposed to be part of hypoxia, and why doesn't it apply here? Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
Jose opined
What would it feel like to breathe nitrogen instead of oxygen or air? I presume one would just get euphoric, pass out, and die, with nary a clue. Skip the euphoria, and you have your answer. Ok, then what causes the euphoria which is supposed to be part of hypoxia, and why doesn't it apply here? A pure N2 atmosphere has no O2. So unconsciousness occurs quickly, and unexpectedly, leaving no time for euphoria. It is not quit as fast as decompressioin, but fast with no warning. Scroll down http://www.cfht.hawaii.edu/~warren/s...nicLiquids.htm for example. -ash Cthulhu in 2005! Why wait for nature? |
servicing oxygen systems with nitrogen would be a very bad thing. What would it feel like to breathe nitrogen instead of oxygen or air? I presume one would just get euphoric, pass out, and die, with nary a clue. Yep. No buildup of CO2. Everything would feel just fine. Just a bit of warning dizziness. moo |
In a previous life I was in aircraft maintenance. Aviator's breathing oxygen systems were serviced from just two sources; compressed oxygen bottles or liquid oxygen carts. The only other compressed gas bottle used for servicing aircraft was nitrogen. I don't recall what measures were taken to prevent servicing oxygen systems with nitrogen, other than colors and markings on the bottles, but servicing oxygen systems with nitrogen would be a very bad thing. Different fittings. moo |
Sport Pilot pilots not insurable? | Blueskies | Piloting | 14 | July 12th 05 05:45 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
