Descent below MDA -- what would you do?
Old August 19th 05, 05:14 AM
Steven P. McNicoll
"gman" wrote in message
For both.
FAR 91.155(c) states, " Except as provided in §91.157, no person may operate
an aircraft beneath the ceiling under VFR within the lateral boundaries of
controlled airspace designated to the surface for an airport when the
ceiling is less than 1,000 feet." That refers to a surface area.
From the Pilot/Controller Glossary:
SURFACE AREA- The airspace contained by the lateral boundary of the Class B,
C, D, or E airspace designated for an airport that begins at the surface and
extends upward.
The procedures for establishing surface areas are found in FAA Order 7400.2,
"Procedures for Handling Airspace Matters". There are two requirements that
must be met prior to establishing a surface area:
1.) Communications capability with aircraft must exist down to the runway
surface of the primary airport either directly with ATC or by rapid relay
through another communications facility which is acceptable to ATC, such as
a FSS.
2.) Weather observations must be taken at the primary airport during the
time of designation of the surface area.
Old August 19th 05, 01:32 PM
Roy Smith
extends upward.
I probably should know this, but now that I (re-)read the above, I see that
there's several ways to parse that sentence with respect to B and C
airspace:
1) Only the inner cylinder that touches the surface is the surface area,
i.e. SVFR is not available in the outer rings of B/C airspace.
2) The boundaries of the surface area are exactly the same (vertical and
lateral) as the B/C airspace. This is what I had always assumed.
3) The surface area includes all the airspace from the edge of the
outermost ring projected down to the surface. This would be extremely
illogical, but it is one possible parsing.
Which is correct?
Is there such a thing as B, C, or D airspace in the US which is not
"designated for an airport"?
Old August 19th 05, 02:52 PM
Steven P. McNicoll
"Roy Smith" wrote in message
that there's several ways to parse that sentence with respect to B and C
airspace:
Which is correct?
Prior to airspace reclassification there were control zones within and
distinct from ARSAs and TCAs and SVFR was clearly limited to just the
control zone. If SVFR was now available within the entire Class B or Class
C airspace it would mean a major change that was not mentioned or discussed
during reclassification.
FAR 91.155(c) states, "Except as provided in FAR 91.157, no person may
operate an aircraft beneath the ceiling under VFR within the lateral
boundaries of controlled airspace designated to the surface for an airport
when the ceiling is less than 1,000 feet." Since we're only concerned with
the portion within 1000 feet of the surface scenario 2) would be eliminated.
I don't know of any Class B or C like that, but there has been some odd
Class D
airspace areas.
One of them was Pearson Field in Vancouver, WA, about seven miles northeast
of Portland International. Pearson had Class D airspace from the surface
to the overlying Portland Class C airspace. Vancouver had no control tower
and was the only airport in the Class D surface area. Vancouver now has a
Class E surface area.
Another one is adjacent to the Seattle Class B surface area on the west
side. This one still exists, you can view it at the following link:
http://makeashorterlink.com/?F27B2314B
A third one was south of the El Toro MCAS which is now closed, the Class D
airspace apparently was dropped when the base closed. Part of this one
didn't even touch the surface. I have old charts which depict this area, I
can post some images if you're interested.
Old August 19th 05, 03:19 PM
When El Toro closed KSNA lost half of its Class C airspace because of the way
the rules were made piecemeal. It took over a year to get that airspace
modified and redesignated to provide the Class C protection for KSNA that used
to be there when El Toro was operating.
Airspace designations are only as good as the regional airspace staffs
responsible for them.
Old August 22nd 05, 12:57 AM
gman
Steven,
FAR 91.155(c) explicitly refers to "controlled airspace" i.e. airspace
classified as E,D,C,B, and A. Since it is possible to be in E airspace
without being near an airport, it is possible to operate under Special
VFR as long as the requirements in FAR 91.157 are met. Moreover,
ground based weather reporting is NOT required for Special VFR and FAR
91.157 (c)(2) explains what to do if "..ground visibility is not
reported..".
Old August 22nd 05, 03:52 AM
Steven P. McNicoll
Steven,
Yes, it's possible to be in Class E airspace without being near an airport,
but I don't think it's possible to be "within the airspace contained by the
upward extension of the lateral boundaries of the controlled airspace
designated to the surface for an airport" without being near an airport. Do
you?
Moreover, ground based weather reporting is NOT required for Special VFR
and FAR
reported..".
FAR 91.157(c)(1) says no person may take off or land an aircraft (other than
a helicopter) under special VFR unless ground visibility is at least 1
statute mile. If ground visibility isn't being reported it's because the
AWOS/ASOS is on the fritz or the weather observer overslept.
Old August 23rd 05, 05:01 PM
gman
I'm sorry for dragging this thing on but part (a) of the paragraph you
quoted (FAR 91.155) says that if the weather conditions (visibility,
and cloud clearance) are below the prescribed minimums, you cannot
"operate an aircraft under VFR" unless you go Special VFR. The weather
minimums in paragraph 91.155(a) only refer to classes of airspace not
only to those around an airport.
You are correct about FAR 91.155(c,d). However, this rule is in
addition to the other parts of section 91.155.
Since the original poster was on a GPS approach, and most certainly in
controlled airspace, he could have requested a Special VFR clearance
and landed as long as he operated clear of clouds and flight visibility
was greater than 3SM. Even though the airport does not have an
official weather reporting systems, the FARs authorize the pilot to use
his/her own judgment in determining visibility.
Old August 23rd 05, 06:05 PM
Steven P. McNicoll
Since the original poster told us there was no weather reporting at the
destination airport we can conclude there is no surface area because weather
reporting is required to establish a surface area. Since SVFR exists only
in a surface area we can conclude that SVFR was not available even if he had
requested it.
Old August 23rd 05, 08:38 PM
gman
But FAR 91.155(c) says: "_EXCEPT_ as provided in =A791.157, no person
may operate an aircraft beneath the ceiling under VFR within the
lateral boundaries of controlled airspace designated to the surface for
an airport...." That means if you flying under 91.157 (i.e. Special
VFR) you need not comply with 91.155.
Old August 23rd 05, 09:11 PM
Steven P. McNicoll
But FAR 91.155(c) says: "_EXCEPT_ as provided in §91.157, no person
Where can you fly under FAR 91.157?
ASW19b best descent rate on approach (full airbrakes) Robert Sharpe Soaring 1 April 30th 05 11:41 AM
descent below minimums hsm Instrument Flight Rules 82 January 11th 05 06:33 PM
BRS and descent rate Roger Long Piloting 21 May 7th 04 05:34 PM
Avoiding Shock Cooling in Quick Descent O. Sami Saydjari Owning 32 January 21st 04 04:32 AM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
