On Thu, 18 Aug 2005 09:58:18 -0400, "Peter R."
wrote: Greg Copeland wrote: Is this common? How many run their tank(s) dry as part of their fuel management strategy? If you don't run dry, why not? Aside from the heat beat skipping which is sure to follow the first couple of times, what's the down side to this strategy? I would like to do this just one time for each of the two main tanks in the Bonanza V35 I fly if for no other reason than to validate the actual duration and total gallons. However, I have yet to take the time or have the courage to do so. As far as disadvantages, I am concerned about what might happen with the sediment in these aging fuel bladders as the fuel empties. But, I have read articles that dispel this myth so perhaps this is a non-issue. I've run every tank on/in the Deb (35-33) dry. Just not at the same time. At least with the fuel injected engine there is no running rough. It just quits, but you have plenty of time to reach down and turn the fuel selector. This also lets you know if your tanks/bladders are in position and just how much fuel each tank really holds. Take a ruler and keep dipping each tank as you fill. Mark the depths as you fill and you have a calibrated dip-stick. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() On Thu, 18 Aug 2005 09:58:18 -0400, "Peter R." As far as disadvantages, I am concerned about what might happen with the sediment in these aging fuel bladders as the fuel empties. But, I have read articles that dispel this myth so perhaps this is a non-issue. Maybe this one? http://www.avweb.com/news/columns/182044-1.html "The Creeping Crud OWT Then there is the secondary OWT that says something like "But what if some crud gets sucked into the system from the tank bottom?" Give me a break! Think about this, for a moment. There are three areas where "crud" might be a concern. Crud lying on the bottom, crud suspended in the fuel, and crud floating on the surface. When we fuel the airplane, fuel is injected rather violently, stirring up the whole tank. When we fly in turbulence, fuel sloshes rather violently around the tank. Do you really think anything will be peacefully lying on the bottom, year after year? If it were, why would running the tank dry stir it up, and if it's that tenacious, how on earth is running the tank dry going to magically pick it up? How about suspended crud? It is no more, or less likely to be sucked into the fuel lines at any fuel level. Floating crud, on the surface? Well, maybe, but can you name me something that will do that? And if there is, well, how much of it will you allow, before you rip the tank out for "cleaning," or how WILL you get it out, someday? Just how, and when, will you identify it, detect it, and get rid of it? And, how much fuel do you want as a "buffer" below the floating crud, to keep from sucking it in? In fact, if there is a little something floating on the surface, I WANT it to be sucked into the fuel lines, preferably a little at a time, so that the strainers and filters can catch it, and alert me that something is going on in there. The likelihood of there being enough to cause a problem is remote, at best, and if running a tank dry will pick up a little crud, then running a tank dry often is a very good thing, because you'll catch it a little at a time, and drain it out the strainer. Of course, if you keep the tank full most of the time, and the cap on, and drain the sumps often, there isn't any way for crud to get into, or stay in the tank in the first place." |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Engine running again, the good, bad and ugly | Corky Scott | Home Built | 34 | July 6th 05 05:04 PM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
