![]() wrote in message news:r5dNe.22116$Rp5.7682@trnddc03... On 18-Aug-2005, "Doug" wrote: I am quite sure that one can offer an aircraft for hire with an instructor under part 91 with an engine that has gone beyond TBO. My understanding of the "official" FAA interpretation is as follows: Renting an airplane, as opposed to chartering one, does not constitute a commercial, "for hire" use. Hiring of a flight instructor is a separate transaction not tied to the rental of the airplane. Therefore, regulations specifically governing commercial operations do not apply to airplanes that are rented out for instruction or for general use by pilots, regardless of whether dual instruction is given. Of course, if the pilot renting the airplane is going to use it for commercial purposes then the plane must meet commercial use maintenance and operational regulations. Because this interpretation is contrary to widely held belief it is not surprising that a local FSDO would provide a different reading. ------------------------------------- http://www.avweb.com/news/columns/187037-1.html The Savvy Aviator #4: Debunking TBO Engine TBO (time between overhauls) seems to be one of the most misunderstood concepts in aviation maintenance. There are lots of TBO-related old wives tales that are widely believed by owners and mechanic alike, and they can cost owners a great deal of money. Mike Busch endeavors to clear up these misconceptions, and explain what TBO really means. By Mike Busch (MYTH) "While it's true that manufacturer's TBO isn't compulsory for non-commercial (Part 91) operators, commercial (Part 121/135) operators are required to overhaul an engine when it reaches TBO." Not so. Both Lycoming and TCM publish engine TBOs in the form of non-mandatory service bulletins. Some Part 121/135 operators have Operations Specifications that require them to comply with all manufacturer's service bulletins (even non-mandatory ones), while others have Op Specs that require compliance only with mandatory service bulletins. Those in the latter group are no more obligated to comply with published TBO than are Part 91 operators. Those in the former group might theoretically be required to overhaul at published TBO, but most such operators request TBO extensions from their FSDO and these are routinely granted, often for as much as 50% over the engine manufacturer's published TBO. So, in actual practice, published TBO is hardly ever compulsory for any operators -- commercial or non-commercial. |
I agree and have also previously read Mike Busch's article but question
really is whether renting an airplane and providing a flight instructor is a commercial operation, one without Op Specs., where, presumably, the most conservative interpretation would be applied. Do flight schools generally have to overhaul at TBO? Mike MU-2 "Matt Barrow" wrote in message ... wrote in message news:r5dNe.22116$Rp5.7682@trnddc03... On 18-Aug-2005, "Doug" wrote: I am quite sure that one can offer an aircraft for hire with an instructor under part 91 with an engine that has gone beyond TBO. My understanding of the "official" FAA interpretation is as follows: Renting an airplane, as opposed to chartering one, does not constitute a commercial, "for hire" use. Hiring of a flight instructor is a separate transaction not tied to the rental of the airplane. Therefore, regulations specifically governing commercial operations do not apply to airplanes that are rented out for instruction or for general use by pilots, regardless of whether dual instruction is given. Of course, if the pilot renting the airplane is going to use it for commercial purposes then the plane must meet commercial use maintenance and operational regulations. Because this interpretation is contrary to widely held belief it is not surprising that a local FSDO would provide a different reading. ------------------------------------- http://www.avweb.com/news/columns/187037-1.html The Savvy Aviator #4: Debunking TBO Engine TBO (time between overhauls) seems to be one of the most misunderstood concepts in aviation maintenance. There are lots of TBO-related old wives tales that are widely believed by owners and mechanic alike, and they can cost owners a great deal of money. Mike Busch endeavors to clear up these misconceptions, and explain what TBO really means. By Mike Busch (MYTH) "While it's true that manufacturer's TBO isn't compulsory for non-commercial (Part 91) operators, commercial (Part 121/135) operators are required to overhaul an engine when it reaches TBO." Not so. Both Lycoming and TCM publish engine TBOs in the form of non-mandatory service bulletins. Some Part 121/135 operators have Operations Specifications that require them to comply with all manufacturer's service bulletins (even non-mandatory ones), while others have Op Specs that require compliance only with mandatory service bulletins. Those in the latter group are no more obligated to comply with published TBO than are Part 91 operators. Those in the former group might theoretically be required to overhaul at published TBO, but most such operators request TBO extensions from their FSDO and these are routinely granted, often for as much as 50% over the engine manufacturer's published TBO. So, in actual practice, published TBO is hardly ever compulsory for any operators -- commercial or non-commercial. |
My guess would be: Not unless they are carriers (passengers), not merely
commercial operators per se. Note he says even air carriers have gotten waivers up to half again the TBO time. I recall that one of Deakin's articles stated that in the great long ago, the airlines were running the radial engines to DOUBLE their normal TBO time (though we can be certain that the rules have changed even now in the turbine era). The interesting part of the article, though, is his point that you can be wayyyyy below TBO and not be AIRWORTHY. Also, that the most likely time for engine failure is right _after_ TBO, not _ just before_. As for flight schools: Sec. 141.39 Aircraft. An applicant for a pilot school certificate or provisional pilot school certificate must show that each aircraft used by that school for flight training and solo flights meets the following requirements: (a) Each aircraft must be registered as a civil aircraft in the United States; (b) Each aircraft must be certificated with a standard airworthiness certificate or a primary airworthiness certificate, unless the Administrator determines that due to the nature of the approved course, an aircraft not having a standard airworthiness certificate or primary airworthiness certificate may be used; (c) Each aircraft must be maintained and inspected in accordance with the requirements under subpart E of part 91 of this chapter that apply to aircraft operated for hire; 141.91 (???) pertains to Satellite Operations: what the hell are those?) I agree and have also previously read Mike Busch's article but question really is whether renting an airplane and providing a flight instructor is a commercial operation, one without Op Specs., where, presumably, the most conservative interpretation would be applied. Do flight schools generally have to overhaul at TBO? Mike MU-2 "Matt Barrow" wrote in message ... wrote in message news:r5dNe.22116$Rp5.7682@trnddc03... On 18-Aug-2005, "Doug" wrote: I am quite sure that one can offer an aircraft for hire with an instructor under part 91 with an engine that has gone beyond TBO. My understanding of the "official" FAA interpretation is as follows: Renting an airplane, as opposed to chartering one, does not constitute a commercial, "for hire" use. Hiring of a flight instructor is a separate transaction not tied to the rental of the airplane. Therefore, regulations specifically governing commercial operations do not apply to airplanes that are rented out for instruction or for general use by pilots, regardless of whether dual instruction is given. Of course, if the pilot renting the airplane is going to use it for commercial purposes then the plane must meet commercial use maintenance and operational regulations. Because this interpretation is contrary to widely held belief it is not surprising that a local FSDO would provide a different reading. ------------------------------------- http://www.avweb.com/news/columns/187037-1.html The Savvy Aviator #4: Debunking TBO Engine TBO (time between overhauls) seems to be one of the most misunderstood concepts in aviation maintenance. There are lots of TBO-related old wives tales that are widely believed by owners and mechanic alike, and they can cost owners a great deal of money. Mike Busch endeavors to clear up these misconceptions, and explain what TBO really means. By Mike Busch (MYTH) "While it's true that manufacturer's TBO isn't compulsory for non-commercial (Part 91) operators, commercial (Part 121/135) operators are required to overhaul an engine when it reaches TBO." Not so. Both Lycoming and TCM publish engine TBOs in the form of non-mandatory service bulletins. Some Part 121/135 operators have Operations Specifications that require them to comply with all manufacturer's service bulletins (even non-mandatory ones), while others have Op Specs that require compliance only with mandatory service bulletins. Those in the latter group are no more obligated to comply with published TBO than are Part 91 operators. Those in the former group might theoretically be required to overhaul at published TBO, but most such operators request TBO extensions from their FSDO and these are routinely granted, often for as much as 50% over the engine manufacturer's published TBO. So, in actual practice, published TBO is hardly ever compulsory for any operators -- commercial or non-commercial. |
None that I know of. Flight Schools often go beyond TBO. I know FBOs
that can put 2000 hrs on a 172 in 3 years. That engine looks brand new when you open it up. -Robert |
