![]() Doesn't look like a turboprop though. Those look like normal stacks to me. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Looks to me that the prop is fully feathered. Would that not indicate that it's a turbine? |
Thats a turbine, i have worked on one and you can tell because of how
large the exast is and the prop is feathered like a turbine, single engine recipes don't feather all the way. Drew Dalgleish wrote: Doesn't look like a turboprop though. Those look like normal stacks to me. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Looks to me that the prop is fully feathered. Would that not indicate that it's a turbine? |
Missing a few feet of wing in the pictures, for sure, but
that doesn't mean that it happened in flight, nor that it flew that way. I've seen similar pictures of aircraft damaged that way on the ground by trucks or other aircraft, or even by bad landings in strong crosswinds. Even taxying too close to a signpost at excessive speed could do it. The end of the wing is badly mashed and would present huge drag and really serious controllability problems. Let's see: Mashed left wingtip, massive drag requiring all the rudder he has, maybe not enough at that. Loss of lift from mashed wing section (disturbed airflow) requiring extra lift from aileron, which itself is a third gone Loss of lift because part of wing is missing, meaning more aileron required. Those ailerons simply can't make up the difference. And nobody noticed. Right. The engine is probably a Soloy conversion, more common on 206s. An Allison turbine set up to drive a prop. Dan |
So...even though the missing parts were found on the ground in Ireland,
where the flight departed, and the aircraft landed in Jersey missing them, you somehow don't believe it happened??? So. You believe everything you read on the Internet? Just because it's in the paper, or because someone published this "article" on the 'net, doesn't make it true. I'm tired of being sucked into 'net hoaxes. I'm a pilot and an aircraft mechanic. I'm really having trouble believing this one. Dan |
Smitty Two wrote:
I don't know much about airplanes, hopefully enough to stay alive up there, but I think it's entirely plausible that the plane could have flown in that condition, and even that the occupants might not have noticed. What I'm having a devil of a time believing, is that an impact of the magnitude necessary to rip off the wingtip in flight wouldn't have dragged the damn thing out of the sky. Supposedly this happened due to impacting trees just after takeoff, so would I be wrong to assume that there wasn't much airspeed or altitude available for recovery from such a "disturbance?" To me, that's the fishiest part of the story. Add to that it's a high wing. No one noticed the treetops OVER their heads!! -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
So...even though the missing parts were found on the ground in Ireland, where the flight departed, and the aircraft landed in Jersey missing them, you somehow don't believe it happened??? So. You believe everything you read on the Internet? Just because it's in the paper, or because someone published this "article" on the 'net, doesn't make it true. I'm tired of being sucked into 'net hoaxes. Well, a Pinckneyville attendee (who prefers to remain nameless) knows the pilot on the flight and has shared information with me, so yes, I believe it happened. Of course that won't convince you, but since you don't my source yourself, his posting here wouldn't do any good either. I'm guessing that even reports from the IAA or AAIB wouldn't persuade you. I'm a pilot and an aircraft mechanic. I'm really having trouble believing this one. And I'm part-owner of a 182 which hit a tree on a missed approach, ripping off the left wing tip and crushing the leading edge of the left wing from the strut out to what was left, among other damage. The folks on board flew it back from Duluth to Minneapolis in that condition at night. They damned well knew something was wrong, and I'm sure the 210 crew must have as well - that part smells of ass-covering. But it flew, and I believe the 210 did as well. The evidence is incontrovertible. Here's that 210 in happier times, for anyone interested: http://www.pacnetair.com/aircraft.html |
Wrong. A respectably-published report would convince me. I'll wait until someone points it out. The pictures look like it had STD'd fiberglass wing extensions or Flint tip tanks, and if so, that may be all that's missing, not part of the actual wing structure. And not five feet. Whacking off wing structure will often damage the wing root structure as well, causing much more serious damage. Dan |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
