Running dry?
Old August 21st 05, 03:40 AM
Jay Honeck
I'm sorry, was I calling someone a name?
Saying "That is possibly the dumbest thing..." kind of implies the
author is dumb in most interpretations, doesn't it? John Deakin sure is
a lot of things. Dumb is definitely not among them.
Sorry, even Einstein had dumb ideas. This is one of Deakins...
In fact, I would never have guessed that this kind of a hair-brained "fuel
management" procedure would merit a serious discussion in these newsgroups.
To even contemplate running a tank dry in the air, let alone propose it as a
standard -- even beneficial (?!) -- procedure, makes for astonishing
reading.
Although this thread *does* answer a question that has bugged me for a very
long time. I've often wondered how it was possible that so many NTSB
reports ended with "fuel exhaustion" as an explanation.
Now I know.
(And, no, before any "English as a second language" folks misinterpret the
meaning of my post, I DON'T mean that any particular crash happened because
the pilots were purposefully running a tank dry. Rather, it's the "let's
extend our fuel range to the maximum possible" attitude that kills people --
and this thread goes a long ways toward explaining that mentality.)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 21st 05, 03:47 AM
Jose
But this is what aviation =is=.
Aviation is all about limits. We are held up on nothing more than a
blast of air (ob politics: ... and will be brought down by nothing more
than a blast of hot air). In order for that to work, airframes are made
as thin as they can, engines are made as light as they can, reserves are
as thin as they can be... all up to a point. Where that point =is=
(beyond the FARs) is a matter of comfort and physics. If you didn't go
flying unless you had a guaranteed two hours reserve, you'd never go
anywhere. So we cut it down to forty-five minutes - or even half an
hour in clear daylight. Some would consider this reckless, some would
consider it ultra-conservative, but it is what it is - a compromise.
Having only {fill in} reserve is stretching it.
Jose
Quantum Mechanics is like this: God =does= play dice with the universe,
except there's no God, and there's no dice. And maybe there's no universe.
Old August 21st 05, 04:41 AM
Marc J. Zeitlin
"fuel management" procedure would merit a serious discussion in these
newsgroups.
The fact that you consider it "hair-brained" does not make it so.
it as a standard -- even beneficial (?!) -- procedure, makes for
astonishing reading.
Huh. I've run my tanks dry on occasion, for a couple of reasons. First
of all, I wanted to calibrate my new fuel flow gauge. With 56 gallons
in the tanks (28 on each side), I ran one side dry and noted the fuel
used - good within 0.1 gallons out of 28 - I was happy. After I landed,
with 15 gallons left in the other tank (and with a fuel burn on that
trip of about 8.5 gal/hr) I still had almost a 2 hour reserve. It takes
me about 3 seconds to switch tanks, and I do so as soon as I hear the
engine start to stumble. It never stops firing, and it CERTAINLY never
stops rotating - not at 180 Kts TAS at 11.5K ft.
Plus, when I would run one tank dry BEFORE I had the FF gauge, it would
be the only time that I would know EXACTLY how much fuel I had left in
the plane. Seems like something worth knowing.
I'm totally confused as to what the dangerous part of this action might
be. The engine was running before - it'll run after 3 seconds of not
quite getting enough fuel. And since the prop doesn't stop turning (I
have to slow below about 90 Kts before that would happen), it starts
right back up as soon as the fuel returns.
very long time. I've often wondered how it was possible that so many
NTSB reports ended with "fuel exhaustion" as an explanation.
Now I know.
I don't really think that you do. As I noted, I can run a tank dry and
have anywhere from 2.5 to 5 hours of fuel (depending on how fast I want
to go) left in the other side - that's hardly a "fuel exhaustion"
danger - some airplanes don't carry that much fuel when they take off
full.
Marc J. Zeitlin
http://www.cozybuilders.org/
Copyright (c) 2005
Old August 21st 05, 02:04 PM
Ron Lee
Now I know.
full.
Marc J. Zeitlin
I have to agree with Marc on this. I know very accurately how much
fuel I have since I have run the tanks dry to "calibrate" my fuel
gauge (and engine monitor fuel gauge). And yet the closest I have
ever gotten to fuel exhaustion is about one hour of fuel remaining
with several airports between me and my final destination.
I will have to check that one hour number since I did make a fuel stop
in La Junta because my projected remaining fuel in COS was
unacceptable low (about 45 minutes between LHX and COS).
Frankly Jay if you do not wish to ever run a tank dry that is your
decision. I am not critical of it. However, I do not agree with your
assertion that running a tank dry implies the same sort of situational
awareness that leads to exhausting all fuel in flight and making an
off airport landing/crash.
Ron Lee
Old August 21st 05, 04:07 PM
Doug Carter
In article , Ron Lee wrote:
...I have to agree with Marc on this. I know very accurately how much
gauge (and engine monitor fuel gauge)...
That's one way to calibrate the gauge. Perhaps since my Pitts has one tank I
simply drained and refilled it on the ground. The fuel flow gauge is
now accurate to a tenth of a gallon every time I refill.
Old August 21st 05, 05:44 PM
Blanche
I'm not following this thread about running tanks dry. Without an
accurate fuel flow meter (e.g. JPI or EDI) how can you really know
how much fuel is left? Good example - flight from Denver to OSH had
me seeing 132 mph IAS and 155 mph ground speed on the GPS. But I
was also running much higher RPM than usual (almost loaded to the
brim, about 2340/2400 pounds). Great tail wind. But I also used much
more fuel than I planned for due to the higher RPM use.
(remember, my ground is 5500 ft., so I lean by default, which saves
fuel)
In the flat lands, I was unable to lean as much as I usually do,
hence the fuel usage was more than indicated even in the POH and
Lycoming manual for fuel.
Coming home, just the reverse - serious headwinds, high RPM and
more fuel used than I expected. How would knowing a more
accurate fuel capacity help? To me it seems that knowing fuel
usage is more critical than fuel capacity.
Or am I showing my ignorance again? Wouldn't be the first time...
NB: I had planned on installing either JPI or EDI fuel flow meter
this year at the annual but at this point it's a luxury and not
a safety item for me. Since my body doesn't like more than 2 hours
of flying at a time (altho I did 3+ on this past trip) I don't
worry about running out of fuel -- usually.
Old August 21st 05, 06:11 PM
Newps
Without a fuel flow gauge you can't know you're fuel usage unless you
know how much each tank holds. My 182 has 42 gallon bladder tanks. I
recently replaced my left tank with a brand new one. If I wouldn't
have run it dry I would never have known that it actually holds 44 gallons.
Avoid JPI like the plague.
Old August 21st 05, 06:19 PM
Matt Barrow
What does it serve to know FUEL FLOW unless you can calulate that again
CAPACITY?
How does it help to know how much money you spend if you don't know how much
you have in the bank? (Insert joke about "How can I be out of money, I still
have checks in my checkbook?")
Old August 21st 05, 06:20 PM
Roy Smith
My club has been installing JPI's on most of our planes. It is true that
they're over-priced, and have totally inscrutable user interfaces, but this
is true of almost all avionics. What in particular makes you not like JPI?
Old August 21st 05, 08:02 PM
George Patterson
For me, I avoid them because they're absolute *******s. I will not support them
with my money.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Engine running again, the good, bad and ugly Corky Scott Home Built 34 July 6th 05 05:04 PM
It's finally running! Corky Scott Home Built 19 April 29th 05 04:53 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 04:56 PM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
