Roy Smith wrote:
I've only flown a couple of models with tip tanks (Cherokee Six and aftermarket tips on a Bonanza). In both of those, takeoffs and landings are done on the main tanks. I'm guessing that's standard for all tips. Wouldn't it make more sense to drain the tips, *then* drain the mains? On the Cherokee Six, I'd generally start on one main, climb to altitude and after about half an hour, switch to the opposite tip tank. Then to the other tip tank (after I don't remember how long... I think it was 45 minutes). Anyway, it was my intention to burn the tips off first; the theory being that the arm was longer and would have more effect on the weight of the wing, therefore it was a good thing to get those tanks out of the equation first. Subsequently the fuel burn would have a minimal effect on the lateral balance of the aircraft... you could run for an hour on each side before switching again without really feeling it. The mains held 25 gallons each and the tips were 17 each, IIRC. -- Mortimer Schnerd, RN VE |
In article , Mortimer Schnerd, RN wrote:
On the Cherokee Six, I'd generally start on one main, climb to altitude and after about half an hour, switch to the opposite tip tank. Then to the other tip tank (after I don't remember how long... I think it was 45 minutes)... In the Skylane RG I take off on both, cruise on both and land on both. Do newer low wing designs (Cirrus, et al) still require the pilot to disconnect and reconnect the fuel supply while in flight? ![]() |
Doug Carter wrote:
In article , Mortimer Schnerd, RN wrote: On the Cherokee Six, I'd generally start on one main, climb to altitude and after about half an hour, switch to the opposite tip tank. Then to the other tip tank (after I don't remember how long... I think it was 45 minutes)... In the Skylane RG I take off on both, cruise on both and land on both. Do newer low wing designs (Cirrus, et al) still require the pilot to disconnect and reconnect the fuel supply while in flight? I think we are talking about individually selectable tanks ... not systems that take fuel from both tanks simultaneously. I see that this is going to s student list as well. CLASS...do as your instructor tells you and be careful of any opinions expressed on the internet. And don't do stupid things. Ron Lee |
On 2005-08-22, Jay Honeck wrote:
- Checking the accuracy of your fuel gauges? That's absurd -- anyone who relies on fuel gauges is an off-field landing waiting to happen. Some people who don't know how well their fuel gauges are working are also an off-field landing waiting to happen. So you don't know how good your fuel gauges are, so ignore them - then one day, for whatever reason, you have a fuel leak or similar problem - and your watch says you have 1.5 hours remaining, but you really have five minutes remaining. If I own a plane, I damned well make sure the fuel gauges work. I want them in my cross check. Working fuel gauges can tell you that there's a problem. As I said earlier, personally, I don't like running fuel tanks dry, but I will run a tank fairly empty. Consider the Apache I used to fly with four tanks. On a VFR cross country, I like to plan on an hour reserve under normal circumstances. I'd rather not have that one hour divided evenly between four fuel tanks! (Or would you argue an hour reserve is too little?) I'd rather have the vast majority of that hour reserve in one tank. In my plane, it can take 10 to 12 seconds for fuel to feed from one of our tip tanks. If I ran a main tank dry, the prop stopped If you don't have an autofeathering prop, how will it stop? -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
waiting to happen. Some people who don't know how well their fuel gauges are working are also an off-field landing waiting to happen. So you don't know how good your fuel gauges are, so ignore them - then one day, for whatever reason, you have a fuel leak or similar problem - and your watch says you have 1.5 hours remaining, but you really have five minutes remaining. If I own a plane, I damned well make sure the fuel gauges work. I want them in my cross check. Working fuel gauges can tell you that there's a problem. A very good point, and one that I assumed was implicitly understood but -- given the fact that we're cross-posting in the student forum -- should be clearly stated. Our gauges happen to be remarkably accurate in all flight regimes, and at all fuel levels. We watch them carefully -- but always time our fuel AND have a fuel totalizer AND refuel every time we push the plane in the hangar. To say we're anal about fuel management would not be an exaggeration. In my plane, it can take 10 to 12 seconds for fuel to feed from one of our tip tanks. If I ran a main tank dry, the prop stopped If you don't have an autofeathering prop, how will it stop? I suppose you could get too slow to keep the prop turning, although I've not tested this "theory" in flight, for obvious reasons. I've read of this happening to pilots (admittedly in Cubs)... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Our gauges happen to be remarkably accurate in all flight regimes, and at all fuel levels. The gauges in my Maule were also very accurate. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Jay,
Sorry, even Einstein had dumb ideas. This is one of Deakins... Well, while you're certainly entitled to your opinion, it might be prudent to not offer it in such absolute terms in this case. It might be wise to say something like "I wouldn't do it, but if it works for you guys, so be it." Instead, you try to offer pseudo-facts about alleged accidents caused by this. To which, with all due respect, I say: THAT is dumb BS. -- Thomas Borchert (EDDH) |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Engine running again, the good, bad and ugly | Corky Scott | Home Built | 34 | July 6th 05 05:04 PM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
