![]() "Marc Ramsey" wrote in message news ![]() Many in the group fly in the western US, where summer density altitudes range up to 10,000 feet. Yes, the numbers I've run indicate that we need at least a 250 HP turbo diesel (not so much for the HP as the torque) to be able to launch something as mundane as a Grob 103 with two aboard. I'm curious about how these calculations work. At Hobbs, NM, elevation 3,700 feet and long runways, the 90 HP winch, using heavy wire, doesn't have any trouble at all with a Grob 103 loaded with two aboard. Makes me wonder what we are doing wrong. Larry Pardue 2I |
How long is your runway and what altitude do you achieve on launch?
Mike Schumann "Larry Pardue" wrote in message ... "Marc Ramsey" wrote in message news ![]() Many in the group fly in the western US, where summer density altitudes range up to 10,000 feet. Yes, the numbers I've run indicate that we need at least a 250 HP turbo diesel (not so much for the HP as the torque) to be able to launch something as mundane as a Grob 103 with two aboard. I'm curious about how these calculations work. At Hobbs, NM, elevation 3,700 feet and long runways, the 90 HP winch, using heavy wire, doesn't have any trouble at all with a Grob 103 loaded with two aboard. Makes me wonder what we are doing wrong. Larry Pardue 2I |
![]() "Mike Schumann" wrote in message k.net... How long is your runway and what altitude do you achieve on launch? Mike Schumann As I said, long. From about 7,000 to 8,800. Typical altitudes on launch are around 1,500 to 2,000+ feet AGL. Larry Pardue 2I |
Larry Pardue wrote:
"Marc Ramsey" wrote... Many in the group fly in the western US, where summer density altitudes range up to 10,000 feet. Yes, the numbers I've run indicate that we need at least a 250 HP turbo diesel (not so much for the HP as the torque) to be able to launch something as mundane as a Grob 103 with two aboard. I'm curious about how these calculations work. At Hobbs, NM, elevation 3,700 feet and long runways, the 90 HP winch, using heavy wire, doesn't have any trouble at all with a Grob 103 loaded with two aboard. Makes me wonder what we are doing wrong. It is purely a function of ones assumptions when performing the calculations. I'd like to launch a loaded Grob 103 at 8000 foot density altitude, no wind, to 2000 feet from a 5000 foot runway. My basic assumption was that to achieve optimal launch height for a given cable length, one needs to be able to pull hard enough to break the weak link at any point during the climb. I also assumed that there would be 20% mechanical losses. This establishes some relatively high minimum HP and torque levels. If I can I dig up the spreadsheet, I'll post the full set of numbers. None of this says that you can't launch a glider on less horsepower, it just says that you can't get very close to optimal height for a given length of the runway... Marc |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
ANN: SoaringPilot 1.9.8 | Mark Hawkins | Soaring | 0 | April 21st 04 05:09 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
