#161
Thomas Borchert wrote:
RN, If you're worried about fuel, you don't have enough. Well, I, for one, like to worry before I don't have enough. I prefer not to worry period. Ron Lee |
#162
I said "refuel" after every flight, not "top it off" after every flight.
What is the purpose of this? You need to fuel appropriately =before= every flight. That's when the fuel is useful. 2. Install a fuel totalizer. This tells you how much fuel you've used, not how much fuel you have left. It's the fuel you have left that's important. Granted a subtraction will get you there, but that depends on the very assumptions that will bite you one day. What other possible reason is there to do so routinely, *other* than to stretch your range? Every flight stretches one's range. We land with less fuel than we started with. We take off with less runway than we started the takeoff roll with. And leaning the engine, especially aggressively, is also stretching one's range. What is the difference between "stretching one's range" and "getting the maximum (fuel) performance out of the aircraft"? I'm not sure I understand you here. It's the *attitude* of "routinely" running tanks dry that I believe leads to guys running out of gas. It's the attitude of "I know how to do it, and any other way is dumb" that I believe leads to NTSB investigations. Running on the razor's edge of empty in an aircraft is just asking for trouble. Running a tank dry in a cherokee at ten thousand AGL with twenty gallons left in the other tank is not the razor's edge of empty. That said, I do agree that there are some risks to it - a problem may develop with the full tank and you have nothing to go back to. I think I'm more comfortable with some gas in each (of two) tanks, though I'm also comfortable running tip tanks dry at an approriate time and place if I have them (the aircraft I routinely fly don't). But I would not condemn either fuel management principle, nor the pilots who engage in them. Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
#163
![]() Here's an easy way to make sure you never run out of gas Have a 4-hour bladder and 5 hours of fuel. Jim Ricks 1. Refuel after every flight. You will be ready to go for your next flight, and can rest assured that you have gas on board. (Renters will have to switch this to refueling BEFORE every flight.) 2. Install a fuel totalizer. They are cheap (in aviation money), and will tell you your fuel usage to within a few ounces. (Sorry, renters. Get on the FBO to install one.) 3. Never try to stretch your range. Bite the bullet, land and buy gas. 4. Measure your gas with your watch, never your fuel gauges. |
#164
![]() "Ron Rosenfeld" wrote in message ... On Sun, 21 Aug 2005 20:48:12 -0700, "Matt Barrow" wrote: What says a fuel gauge is any more or less accurate than a fuel FLOW gauge? I don't see the relationship of your question to anything I posted. I was agreeing with your counterpoint to someone else who was a FF fanatic :~). But certainly in the ranges over a quarter tank, experience in small a/c show that a properly calibrated fuel flow gauge is more accurate. As a matter of fact, I believe that the fuel quantity indicators are only required to be accurate at zero fuel in level flight (for a/c certified under Part 23). Ummm...no; they must be accurate at all fuel levels. Point is to find out exactly what 1/2, 3/4, ...really means. I do it a couple times a year just to verify the gauge's accuracy. It actually is off my 15 gallons on a full tanks. (Incidentally, those are the only times my tanks are topped off. They hold 98 gallons by the POH, but 99.5 by my measurements. Other than those time, I've never had more than 84 gallons in them and that was for a two leg trip of over 800nm. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#165
Be VERY careful in the Bo with reduced fuel in the tanks!
The leading edge tanks on the Bo cause the C/G to move aft with fuel burn. Starting out with partial fuel means you are starting with the C/G already partially aft. I always calculated both the takeoff and landing C/G when I flew the Bo I had access to. Newps wrote: You must not demand much of your plane. Don't you ever just putz around the local area landing on dirt strips just generally screwing off? I never fill my 182's tanks unless I am going on a long cross country. I normally fly with 30-40 gallons onboard. That 240-300 pounds I'm not carrying makes a big difference in takeoff and landing performance. I'm now in the middle of learning about my Bonanza I will be getting next week. I don't care so much about the top end. Any idiot can push the levers forward and see how fast it will go. I am mostly concentrating on the low speed end. A friend has a V tail similar to mine except his is a couple years older and has the 260 hp motor, mine has 285 hp. I watched him takeoff Saturday. Took him 1400 feet to leave the runway with just him and 80 gallons, no flaps. I was disappointed as my goal is to be able to use a friends 1300 foot runway. Now I already know he always has full tanks. Bo's have bladders and he's afraid of the rubber drying out if he leaves any air in the tanks for more than about 15 minutes. He said he held it on the ground til 80 mph and then yanked it off. Very good news. Take 40 gallons of fuel out, use half flaps and then fly it off at 60 mph with 25 more horsepower weighing about 200 pounds less then he did. Now if you always have full tanks you can't do this stuff. |
#166
As a student, I would like to interject here with a couple of comments
and questions... 1. I have learned from this discussion that everyone has an opinion, and their opinion is quite strongly held. Does anyone have any data, on either side, to back up their opinion? How often do planes have trouble caused by not knowing precisely how much gas they have, perhaps influenced by inaccurate gages? How often do planes have trouble caused by running a tank dry (NOT running the _last_ tank dry)? 2. There seems to be a lot of discussion mentioning that the only way to be sure of your tank's capacity is to run it dry. In my reading about flying, I notice that folks talk about measuring fuel by looking in the tanks and perhaps using a dipstick. Couldn't you calibrate your gages by filling the tanks, going for a flight, then sticking a ruler into the tank to see how much is left? Is running the tank dry any more accurate or useful? To me, the two sides of this debate seems to be as follows: some folks want to be in control of every aspect of their flight, while other folks want to have as wide of a saftey margin as possible at all times. The fuel tank issue is one where these two goals conflict. To the control oriented folks, having a tank run dry when they expect it gives them one more data point which makes them more comfortable and feel more in control during the flight. Any small change in flight characteristics is detectable by a change in tank switch timings, and so these folks are willing to accept what they think is a small risk in changing tanks in order to detect any problems. The safety margin folks feel more comfortable not knowing precisely how much margin of safety they have, as long as that margin is wide enough that they never have to worry about it. To these folks minor problems will be covered by their ample margin of safety, and major problems will become apparent on their gages. These folks want to make sure they have as much fuel as possible in reserve in all tanks when the major problem hits, and don't worry about missing a couple of minor problems as a result. Is my characterization accurate? Chris -- Chris Colohan Email: PGP: finger Web: www.colohan.com Phone: (412)268-4751 |
#167
![]() "john smith" wrote in message ... Be VERY careful in the Bo with reduced fuel in the tanks! The leading edge tanks on the Bo cause the C/G to move aft with fuel burn. Where would the CG be with mid-wing tanks? Further aft? Starting out with partial fuel means you are starting with the C/G already partially aft. I always calculated both the takeoff and landing C/G when I flew the Bo I had access to. All you need do is NOT overload the rear seats/baggage area. I assume he's getting a V-tail; CG is much better with a straight tail (yet still a bit narrow). Upgrading to an IO-550 from a IO-520 also moves the CG a couple inches forward IIR. |
#168
![]() "Chris Colohan" wrote in message .. . As a student, I would like to interject here with a couple of comments and questions... 1. I have learned from this discussion that everyone has an opinion, and their opinion is quite strongly held. Does anyone have any data, on either side, to back up their opinion? How often do planes have trouble caused by not knowing precisely how much gas they have, perhaps influenced by inaccurate gages? How often do planes have trouble caused by running a tank dry (NOT running the _last_ tank dry)? http://www.avweb.com/news/columns/182044-1.html http://www.aopa.org/asf/publications...ndex.html#fuel (The most common excuses are along the lines of "I though it was full when I took of, so I didn't check it"). http://www.aopa.org/asf/publications/sa16.pdf 2. There seems to be a lot of discussion mentioning that the only way to be sure of your tank's capacity is to run it dry. In my reading about flying, I notice that folks talk about measuring fuel by looking in the tanks and perhaps using a dipstick. Couldn't you calibrate your gages by filling the tanks, going for a flight, then sticking a ruler into the tank to see how much is left? Is running the tank dry any more accurate or useful? Better to run ONE dry, land, and fill it to the rim and read the numbers on the fuel truck. NEVER run it dry when it is unintentional. Also, never run it dry intentionally when you don't know within a few minutes of WHEN it's going to cut out AND ARE WATCHING FOR IT TO CUT OUT. To me, the two sides of this debate seems to be as follows: some folks want to be in control of every aspect of their flight, while other folks want to have as wide of a saftey margin as possible at all times. The fuel tank issue is one where these two goals conflict. See the AvWeb article at the URL above. To the control oriented folks, having a tank run dry when they expect it gives them one more data point which makes them more comfortable and feel more in control during the flight. Any small change in flight characteristics is detectable by a change in tank switch timings, and so these folks are willing to accept what they think is a small risk in changing tanks in order to detect any problems. The safety margin folks feel more comfortable not knowing precisely how much margin of safety they have, as long as that margin is wide enough that they never have to worry about it. To these folks minor problems will be covered by their ample margin of safety, and major problems will become apparent on their gages. These folks want to make sure they have as much fuel as possible in reserve in all tanks when the major problem hits, and don't worry about missing a couple of minor problems as a result. One problem with fuel planning is when things don't shape up as expected (headwinds, holds due to weather...), but how do you plan alternative actions if your only know, in a fuzzy fashion, how much fuel you have. Yeah, it's always better to play it safe, land, and take on both airplane and people fuel...but when if that alternative is not immediately available. Fly over the Colorado Rockies sometime during widespread, low weather and your nearest fual can be esaily a half an hour away or more. Is my characterization accurate? Pretty much. |
#169
Thomas Borchert wrote: Neil, I would feel more comfortable with 4 in each tank than with a dry tank. Well, I definitely wouldn't, the odd and very rare fuel selector malfunction notwithstanding. Nor would I! I would rather have an hour in ONE tank, rather than spread among FOUR tanks! How would you know which tank to select for landing? I would not want to select the 5 minute tank, when I would have to go around! Those are the guys who run into fuel starvation problems! |
#170
and questions... [...] How often do planes have trouble caused by running a tank dry (NOT running the _last_ tank dry)? I would make this two parts - one for =deliberately= running a tank (not the last tank) dry, and the other for =accidentally= doing the same. Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Engine running again, the good, bad and ugly | Corky Scott | Home Built | 34 | July 6th 05 05:04 PM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
