At 12:18 22 August 2005, Afsax wrote:
I don't see anything to indicate that it wouldn't be legal to stick with the metric instruments as long as it meets the type certificate requirements, which it seems to. I will install a second TSO'd feet altimeter since charts and everything in the states is in feet, but I don't see why I'd have to change anything else. I know of at least one YAK airplane that has retained all of its original instruments except for a new feet altimeter and a transponder. If anyone has any other experiences let me know. Adam Except, perhaps, the ASI - so as not to confuse 50 kph with 50 knots in the heat of the moment ! This has, I am told, happened - with unfortunate consequences. I have imported a glider from Germany (to the UK) - and replaced the ASI and altimeter only - but left the fancy push/pull variometer and the (absolutely brilliant) Winter 'Sollfahrtgeber' entirely alone - with, absolutely, no problems. sta13nski. |
Stanford Korwin wrote:
At 12:18 22 August 2005, Afsax wrote: I don't see anything to indicate that it wouldn't be legal to stick with the metric instruments as long as it meets the type certificate requirements, which it seems to. I will install a second TSO'd feet altimeter since charts and everything in the states is in feet, but I don't see why I'd have to change anything else. I know of at least one YAK airplane that has retained all of its original instruments except for a new feet altimeter and a transponder. If anyone has any other experiences let me know. Adam Except, perhaps, the ASI - so as not to confuse 50 kph with 50 knots in the heat of the moment ! This has, I am told, happened - with unfortunate consequences. I have imported a glider from Germany (to the UK) - and replaced the ASI and altimeter only - but left the fancy push/pull variometer and the (absolutely brilliant) Winter 'Sollfahrtgeber' entirely alone - with, absolutely, no problems. sta13nski. I really wouldn't worry about the ASI. I fly my Open Cirrus (in the UK) on metric instruments. Its stall speed is lower than most glass gliders at (book figure) 63 kph. If I try to fly the approach at 50 kph, mistaking this for kt, I will realise my mistake in plenty of time to correct the stall. I must say that because the difference is nearly 100% between kt and kph I've never had a moment's confusion. I can't imagine anyone having this problem on the launch either, as the aircraft won't be flying at the 55 kph mark. However, mph and kt seems to me like a recipe for disaster if you fly an approach at the kt speed using an mph ASI. |
On Mon, 22 Aug 2005 15:02:37 +0100, Chris Reed wrote:
I really wouldn't worry about the ASI. I fly my Open Cirrus (in the UK) on metric instruments. Its stall speed is lower than most glass gliders at (book figure) 63 kph. If I try to fly the approach at 50 kph, mistaking this for kt, I will realise my mistake in plenty of time to correct the stall. I must say that because the difference is nearly 100% between kt and kph I've never had a moment's confusion. I can't imagine anyone having this problem on the launch either, as the aircraft won't be flying at the 55 kph mark. Agreed. I've done virtually all my gliding in the UK using kts/ft instruments. However, in 2003 I visited the Wasserkruppe and flew there with no problems. Check ride was in an ASK-21. The ASI was the same model with the same coloured snake but a different numeric scale. My club has a couple of ASK-21s which I fly fairly regularly, so I know the sounds and where the needle should point so I had no problems. They then gave me a flight in an ASK-23, which I'd not flown before, but this time I was briefed with the right speeds, so again no problem. I was more bothered flying a kts/ft ASK-21 in America than I was flying the German metric one because for some reason known only to history and the FAA, American ASIs are upside down: at cruising speed the needle is straight down, not upright as it should be. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Except, perhaps, the ASI - so as not to confuse 50 kph with 50 knots in the heat of the moment ! This has, I am told, happened - with unfortunate consequences. I have imported a glider from Germany (to the UK) - If the glider was certificated in Germany, then I suspect it has a green arc, a yellow arc, a red line and, most helpful, a yellow triangle. Stefan |
Metric measuring tool source? | DL152279546231 | Home Built | 12 | April 29th 04 02:13 AM |
Reverse Vacuum Damging to Instruments? | O. Sami Saydjari | Owning | 8 | February 16th 04 04:00 AM |
metric system newsgroup call for votes #1 | Paul Hirose | Military Aviation | 72 | November 16th 03 06:59 PM |
Edwards air show B-1 speed record attempt | Paul Hirose | Military Aviation | 146 | November 3rd 03 05:18 PM |
Wanted - Metric Altimeters | RHWOODY | Soaring | 0 | September 13th 03 10:20 PM |
