GPS questions
Old August 23rd 05, 04:18 PM
Newps
Jay Honeck wrote:
Jay, I've flown with the terrain feature of a GPS. It is a complete waste
of money for a VFR pilot. It's even useless out here where we actually
have terrain. If where you fly there is a lot of antennas and you often
scud run and are dodging these antennas then an obstruction database may
be of some use.
Yeah, we've got the antennas depicted on both the AvMap and the Lowrance
2000c, and they're nice to have.
And some of 'em you don't even need to be scud running to hit. Those danged
things are thousands of feet tall around here!
Last I heard the tallest man made structure was the TV antenna between
Fargo and Grand Forks at 2000 AGL. The vast majority of antennas are
much less than 1000.
Old August 23rd 05, 04:38 PM
N93332
"Newps" wrote in message
Fargo and Grand Forks at 2000 AGL. The vast majority of antennas are much
less than 1000.
Back in the 70's they built towers between Des Moines and Ames that were
2000 agl (2998msl). Looking at a Chicago sectional shows several antennae
around 1500-2000 agl in Jay's neighborhood.
Old August 23rd 05, 06:37 PM
Don Tuite
Just south of Sacramento, there is a cluster of four 2000-footers (The
southernmost two are 2049.) They're in the delta, so their absolute
height is the same as their AGL height. We've also got a 1500-footer
on top of a 3000-foot ridge between San Jose and Watsonville.
Otherwise, yes.
Don
Old August 23rd 05, 07:41 PM
John Clear
I took some pics of the one on the ridge between Watsonville and
South County awhile back.
http://www.clear-prop.org/spot-the-tower/
Those ones in the delta are pretty impressive too. At least they
are painted in high visability colors. The one on the ridge is
flat grey.
John
John Clear - http://www.clear-prop.org/
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
