Jay Honeck wrote:
It seems like we're having to fill the tires way too often. At least every 3 - 4 weeks, we notice that the plane has become a real bear to pull out of the hangar, and that our take-off roll has become noticeably longer. Sure enough, the tires will be down around 25%, from 40 to 30 lbs on the mains, and from 30 to 23 lbs (or so) in the nosewheel. This doesn't seem unreasonable for standard aviation tubes. I've read several different things about them and what it boils down to is that the rubber they've always used is somewhat porous (on a molecular level). There are a few new types of tubes on the market, the most popular being the Michelen "Air Stop" (I think) that use a better rubber that doesn't leak. I've heard that they pretty much keep there tire pressure indefinitely. I believe there have been posts on both r.a.owning as well as the Cherokee Chat confirming this. I'm switching at the next tire change. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Tires again (but this time on the tow vehicle) | Papa3 | Soaring | 37 | February 7th 05 02:30 PM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Owning | 0 | March 20th 04 04:48 AM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Restoration | 0 | March 20th 04 04:48 AM |
Flat Spin | JJ Sinclair | Soaring | 34 | February 10th 04 05:57 PM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
