With NO changes in engine horsepower, NO changes in wing design, NO changes
in nothing else except a net NEGATIVE CHANGE in rudder area ... How (in an engineering sense) did they do that? Jim "Dale" wrote in message ... Gross weight on the 182 is 2550 pounds, the 182A and 182B gross at 2650. Gross didn't get up to 2950 pounds until they put the girlie swept tail on them. -- Dale L. Falk |
changes in nothing else except a net NEGATIVE CHANGE in rudder area ... How (in an engineering sense) did they do that? Jim, it's an FAA thing. 'Nuff said. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 2005-08-25, RST Engineering wrote:
With NO changes in engine horsepower, NO changes in wing design, NO changes in nothing else except a net NEGATIVE CHANGE in rudder area ... How (in an engineering sense) did they do that? There was another change - limiting the flap extension (IIRC) from 40 degrees to 30 degrees. Part of what decides gross weight is go around performance with full flaps. You can get a 100lb gross weight increase in some models of C172 just by limiting the flap extension to 30 degrees with a plate that prevents you moving the flap switch past the 30 degrees setting. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
![]() Dylan Smith wrote: On 2005-08-25, RST Engineering wrote: With NO changes in engine horsepower, NO changes in wing design, NO changes in nothing else except a net NEGATIVE CHANGE in rudder area ... How (in an engineering sense) did they do that? There was another change - limiting the flap extension (IIRC) from 40 degrees to 30 degrees. No 182 is limited to 30 degrees. |
"RST Engineering" wrote: How (in an engineering sense) did they do that? Jim They got out their little engineers eraser and engineers pencil and changed the numbers. The 30 degree flaps didn't come along until way late in the 182's life...gross was up over 3000 pounds, IIRC, before the flaps were limited. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Engine running again, the good, bad and ugly | Corky Scott | Home Built | 34 | July 6th 05 05:04 PM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
