Sandy Stevenson wrote:
I've been looking for an expalantion of the aerodynamics of how an aircraft gets into a spiral dive. "In the process of learning gliding turns, a beginner may fail to control the tendencies to overbank and to dive. The bank may approach the vertical and the nose of the glider may fall more than 45 degress below the the horizon; of course, speed will increase rapidly." -Page 18, The Joy of Soaring by Carle Conway "Sometimes the elevator is unable to keep the wing stalled beyond the incipient stage of the spin. In this case, as the nose and wing drop, the wing will unstall and the speed will increase with the glider in a spiral dive." -Page 127, Gliding, Sixth Edition, by Derek Piggott but I don't yet understand how it comes about that adding back pressure increases one's airspeed. "If the pilot then pulls the stick back in a mistaken effort to slow the glider or to bring its nose back up to the horizon, the glider will simply turn faster and the spiral will continue to steepen. The resulting increase in the angle of attack and airspeed could overload the wing to the point of structural failure." -Page 18, The Joy of Soaring by Carle Conway (paragraph following that quoted previously from Conway) "..., during the spiral dive you will learn that the effect of backward motion on the control stick will not raise the nose of the glider (and consequently is useless in trying to recover from the dive). This is because the steep bank means that any increase in angle of attack of the wing will generate more lifting force inward--tightening the turn--than it will upward. Tightening the turn only results in greater loads, airspeed, and sink rate, and eventually could lead to failure of the glider." -Page 76, Learning to Fly Gliders by Bob Wander If someone could point me to a good explanation of what's going on aerdynamically when an aircraft is in a spiral dive, I'd appreciate it. |
| Thread Tools | |
| Display Modes | |
| Paraglider spiral dive, throws chute and ends up in the trees | Stewart Kissel | Soaring | 8 | March 1st 05 11:04 PM |
| inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 04:32 PM |
| Fuel injection explanation | [email protected] | Piloting | 18 | June 23rd 04 03:57 AM |
