On 8/25/2005 11:37, gwengler wrote:
Even in the USA, no-DME restricts the choice of a destination/alternate, IIRC. How so? Gerd If you're flying a GPS approach at your primary airport, the alternate airport must have a non-GPS IAP. If the only non-GPS IAP requires DME, then you need to have DME operational in the aircraft. Keep in mind that I did not cite all the rules/regs concerning this issue, just the part that illustrates this point. -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA |
On Thu, 25 Aug 2005 12:35:35 -0700, Mark Hansen
wrote: On 8/25/2005 11:37, gwengler wrote: Even in the USA, no-DME restricts the choice of a destination/alternate, IIRC. How so? Gerd If you're flying a GPS approach at your primary airport, the alternate airport must have a non-GPS IAP. If the only non-GPS IAP requires DME, then you need to have DME operational in the aircraft. Keep in mind that I did not cite all the rules/regs concerning this issue, just the part that illustrates this point. Mark, That's true for most GPS receivers certified under TSO 129, but not true for WAAS enabled units certified under TSO 146. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Barometer Setting in Europe question... | Piloting | 19 | April 3rd 05 09:43 PM | |
Flying Holiday in Europe | Udo Rumpf | Soaring | 17 | March 23rd 05 03:08 PM |
USA armed URSS to keep down Europe | IO | Military Aviation | 9 | October 21st 03 07:19 AM |
Airmen in Europe may go back to three-month rotation schedules | Otis Willie | Military Aviation | 0 | August 22nd 03 11:47 PM |
Could it happen he The High Cost of Operating in Europe | Larry Dighera | Piloting | 5 | July 14th 03 02:34 AM |
