![]() Quote:
I bought my first glider (Mini-Nimbus) shortly before I took my checkride. I had far fewer hours than you. My very first flight in a flapped ship was after I passed my checkride and the insurance company allowed me to fly my own ship. The flaps were a complete non-event. I was then and am still today much more concerned with remembering that I have retractable gear. The flaps help when you care to use them, but frankly, were never a bit of distraction from the "blue up/green down" aspects of flying. Some folks here have spoken of getting in trouble with a positive flaps setting when too low on final. Trust me: if you are remotely paying attention, you will notice a distinct nose down attitude that tells you the flaps are set positive. Changing them to neutral will bring the nose up and also give you an instant but slight acceleration. Both of those are good if low on final. If you are the sort who would be low on final and not think to adjust your flaps setting, perhaps flying is not the sport for you regardless what class plane you are flying. Furthermore, flaps allow you to always arrive a bit high, since you can shed altitude more quickly than some other ships. Buy the best ship you can afford and learn to fly it well, whatever it is. And remember to have fun. Steve |
I agree with 95% of your statement. Having "signed off" quite a few low
time pilots for their first time fllight in flaps, and BTW CG hooks, I have not had anyone have a big problem with flaps. Just remember that the "full bore" landing flaps are not to be used till *after* the turn to final *and * you have the field made no matter what. However, I worry that some will misinterpret what you said about reducing flaps if low on final. This must only be done very carefully or not at all, as there is a loss of altitude and a sinking feeling. It must be done early in the final approach phase or it won't do much good and will lose altitude. The "spot in the windshield" must be established early. Since this "spot" must allow for increased sink on short final, it should not be the very beginning of the runway. Having "experimented" with this with a ASW27, the loss is about 50 feet. I have not flown the like of a PIK or HP, but have flown a ASW20B--I'd bet the HP would lose more. Just dont try this for the first time at 100 ft height--try at 2000ft in your ship and see what happens. -- Hartley Falbaum CFIG USA "Vic7" wrote in message ... skysailor Wrote: The big kahuna's in the club are pretty adamant about purchasing a first glider without flaps. My question is: Are flaps that big a problem for a low time pilot and why? To answer your questions: no, and I have no idea why they think so. I bought my first glider (Mini-Nimbus) shortly before I took my checkride. I had far fewer hours than you. My very first flight in a flapped ship was after I passed my checkride and the insurance company allowed me to fly my own ship. The flaps were a complete non-event. I was then and am still today much more concerned with remembering that I have retractable gear. The flaps help when you care to use them, but frankly, were never a bit of distraction from the "blue up/green down" aspects of flying. Some folks here have spoken of getting in trouble with a positive flaps setting when too low on final. Trust me: if you are remotely paying attention, you will notice a distinct nose down attitude that tells you the flaps are set positive. Changing them to neutral will bring the nose up and also give you an instant but slight acceleration. Both of those are good if low on final. If you are the sort who would be low on final and not think to adjust your flaps setting, perhaps flying is not the sport for you regardless what class plane you are flying. Furthermore, flaps allow you to always arrive a bit high, since you can shed altitude more quickly than some other ships. Buy the best ship you can afford and learn to fly it well, whatever it is. And remember to have fun. Steve -- Vic7 |
I have not experienced any drop,
provided the approach is flown at proper "approach speed". When the flap is retracted from any position even as high as +90 deg. at a constant rate and the "same speed" is maintained no drop is experienced. In fact the rate of decent is reduced. Since one is flying at the proper speed, the sink rate with zero flap is less by a factor of five or more. This requires that the nose is raised at the same time as the flap is retracted. Only when the fence or thresholds is reach should the glider be slowed below the approach speed. Once experience has been gained a more flexible approaches are possible. Naturedly if you fly 1.3 time the stall speed for given flap setting you will invite trouble. This would be about 40 kt. with +90 deg. If you were to reduce the flap to zero at that speed you would stall or if one still has flying speed the sink rate would be high. For the first time flapped only glider pilot, I recommend the following. If the wing loading is around seven lb the approach speed should be about 55 Kt . Take a high tow, play with the flaps and maintain proper speed of 55 kt at all flap settings. Enter the landing pattern. You should have all the correct heights at all points along the way. The only difference, with a flapped only glider fly it closer in on final by about 50% for the same height. Crank in full flaps and point the glider to the fence. Maintain 55 kt. The sense you will have is standing in the cockpit but the fuselage only will point down about 30 deg.. Hold that nose down position till about 10-15 feet off the ground. Round out positively and let the glider settle on it own, You will not have the shortest landing but a save first experience. ( When I made my first flight I took the glider to an airport with a very long grass run way, as my club at the time only had a 2000 ft strip.) Regards Udo "HL Falbaum" wrote in message ... I agree with 95% of your statement. Having "signed off" quite a few low time pilots for their first time fllight in flaps, and BTW CG hooks, I have not had anyone have a big problem with flaps. Just remember that the "full bore" landing flaps are not to be used till *after* the turn to final *and * you have the field made no matter what. However, I worry that some will misinterpret what you said about reducing flaps if low on final. This must only be done very carefully or not at all, as there is a loss of altitude and a sinking feeling. It must be done early in the final approach phase or it won't do much good and will lose altitude. The "spot in the windshield" must be established early. Since this "spot" must allow for increased sink on short final, it should not be the very beginning of the runway. Having "experimented" with this with a ASW27, the loss is about 50 feet. I have not flown the like of a PIK or HP, but have flown a ASW20B--I'd bet the HP would lose more. Just dont try this for the first time at 100 ft height--try at 2000ft in your ship and see what happens. -- Hartley Falbaum CFIG USA "Vic7" wrote in message ... skysailor Wrote: The big kahuna's in the club are pretty adamant about purchasing a first glider without flaps. My question is: Are flaps that big a problem for a low time pilot and why? To answer your questions: no, and I have no idea why they think so. I bought my first glider (Mini-Nimbus) shortly before I took my checkride. I had far fewer hours than you. My very first flight in a flapped ship was after I passed my checkride and the insurance company allowed me to fly my own ship. The flaps were a complete non-event. I was then and am still today much more concerned with remembering that I have retractable gear. The flaps help when you care to use them, but frankly, were never a bit of distraction from the "blue up/green down" aspects of flying. Some folks here have spoken of getting in trouble with a positive flaps setting when too low on final. Trust me: if you are remotely paying attention, you will notice a distinct nose down attitude that tells you the flaps are set positive. Changing them to neutral will bring the nose up and also give you an instant but slight acceleration. Both of those are good if low on final. If you are the sort who would be low on final and not think to adjust your flaps setting, perhaps flying is not the sport for you regardless what class plane you are flying. Furthermore, flaps allow you to always arrive a bit high, since you can shed altitude more quickly than some other ships. Buy the best ship you can afford and learn to fly it well, whatever it is. And remember to have fun. Steve -- Vic7 |
I second that. I have retracted from 55 deg flap to thermal position less
than 5 meters above the runway, and if memory serves me right, I didn't crash :-) -- Bert Willing ASW20 "TW" "Udo Rumpf" a écrit dans le message de news: ... I have not experienced any drop, provided the approach is flown at proper "approach speed". When the flap is retracted from any position even as high as +90 deg. at a constant rate and the "same speed" is maintained no drop is experienced. In fact the rate of decent is reduced. Since one is flying at the proper speed, the sink rate with zero flap is less by a factor of five or more. This requires that the nose is raised at the same time as the flap is retracted. Only when the fence or thresholds is reach should the glider be slowed below the approach speed. Once experience has been gained a more flexible approaches are possible. Naturedly if you fly 1.3 time the stall speed for given flap setting you will invite trouble. This would be about 40 kt. with +90 deg. If you were to reduce the flap to zero at that speed you would stall or if one still has flying speed the sink rate would be high. For the first time flapped only glider pilot, I recommend the following. If the wing loading is around seven lb the approach speed should be about 55 Kt . Take a high tow, play with the flaps and maintain proper speed of 55 kt at all flap settings. Enter the landing pattern. You should have all the correct heights at all points along the way. The only difference, with a flapped only glider fly it closer in on final by about 50% for the same height. Crank in full flaps and point the glider to the fence. Maintain 55 kt. The sense you will have is standing in the cockpit but the fuselage only will point down about 30 deg.. Hold that nose down position till about 10-15 feet off the ground. Round out positively and let the glider settle on it own, You will not have the shortest landing but a save first experience. ( When I made my first flight I took the glider to an airport with a very long grass run way, as my club at the time only had a 2000 ft strip.) Regards Udo "HL Falbaum" wrote in message ... I agree with 95% of your statement. Having "signed off" quite a few low time pilots for their first time fllight in flaps, and BTW CG hooks, I have not had anyone have a big problem with flaps. Just remember that the "full bore" landing flaps are not to be used till *after* the turn to final *and * you have the field made no matter what. However, I worry that some will misinterpret what you said about reducing flaps if low on final. This must only be done very carefully or not at all, as there is a loss of altitude and a sinking feeling. It must be done early in the final approach phase or it won't do much good and will lose altitude. The "spot in the windshield" must be established early. Since this "spot" must allow for increased sink on short final, it should not be the very beginning of the runway. Having "experimented" with this with a ASW27, the loss is about 50 feet. I have not flown the like of a PIK or HP, but have flown a ASW20B--I'd bet the HP would lose more. Just dont try this for the first time at 100 ft height--try at 2000ft in your ship and see what happens. -- Hartley Falbaum CFIG USA "Vic7" wrote in message ... skysailor Wrote: The big kahuna's in the club are pretty adamant about purchasing a first glider without flaps. My question is: Are flaps that big a problem for a low time pilot and why? To answer your questions: no, and I have no idea why they think so. I bought my first glider (Mini-Nimbus) shortly before I took my checkride. I had far fewer hours than you. My very first flight in a flapped ship was after I passed my checkride and the insurance company allowed me to fly my own ship. The flaps were a complete non-event. I was then and am still today much more concerned with remembering that I have retractable gear. The flaps help when you care to use them, but frankly, were never a bit of distraction from the "blue up/green down" aspects of flying. Some folks here have spoken of getting in trouble with a positive flaps setting when too low on final. Trust me: if you are remotely paying attention, you will notice a distinct nose down attitude that tells you the flaps are set positive. Changing them to neutral will bring the nose up and also give you an instant but slight acceleration. Both of those are good if low on final. If you are the sort who would be low on final and not think to adjust your flaps setting, perhaps flying is not the sport for you regardless what class plane you are flying. Furthermore, flaps allow you to always arrive a bit high, since you can shed altitude more quickly than some other ships. Buy the best ship you can afford and learn to fly it well, whatever it is. And remember to have fun. Steve -- Vic7 |
On Fri, 26 Aug 2005 16:33:00 +0200, "Bert Willing"
wrote: I second that. I have retracted from 55 deg flap to thermal position less than 5 meters above the runway, and if memory serves me right, I didn't crash :-) Unlock the flap lever in your 20 at a height of about 2 meters (... if necessary I can tell you how to do that...) and you'll get the experience of a purely ballistic impact one second later. I think in the end it's a question of many factors - situational awareness (remember to pull up the nose while retracting the flaps, remembering not to overshoot the desired setting), training, and feeling (coordination of flap retraction, pulling on the stick and controlling the speed). If the pilot is alert and knows what he's doing, there is not going to be any problem. If not, some gliders are going to punish the pilot more than others. Reading about Udo's story of first flying a flapped ship with 14 glider hours (most of my students have mor hours when they solo) on a airport with a long runway because his home airport's runway is only 2.000 ft makes me think about how different the situation is in the US/Canada compared to good ole' Europe... ![]() Bye Andreas |
![]() Bert Willing wrote: Been there, done that (not properly locked the flaps when set). You need to react very fast on the stick, and you should have carried some extra speed before. Of course I agree with Roy - you can do a lot of things if you have the required experience... (and for the ASW20, I happen to have a couple of hundred hours on that glider). As for novice counsel, a newsgroup doesn't help anybody very much. You normally don't know where the advice comes from, and if you really want to have advice on how to fly or what glider to buy, you talk to instructors or experienced people *at an airfield*. Newsgroups are rather, hm, amusing gossip? I agree that one must be careful when getting "advice" from a newsgroup or lots of places on the internet. In my case I first sought information on how to fly my RS-15 (flaps only) from at least three different CFIGs at two different airfields. The only "help" I got was a lecture from one CFIG in California on how flaps only could get me in trouble in strong lift just beneath a cloud. But I really don't blame those CFIGs because they simply had no experience with this type of glider. As it turned out I received a lot of very valuable information from people belnging to a Yahoo Group dedicated to that type of glider. But your point about being careful of the source of information on the internet is a good one. Btw, regarding advice on what glider to buy: The head of the FBO was convinced I could not handle the RS and would likely spin it in straight away. Since I was relying on him at the time to get my license, that became an "issue". We had words. I eventually discovered the flight characteristics of the RS to be very gentle and an overall pleasure to fly. Compared to the G-103 which I had been training in the RS felt "spin-proof". But I was needlessly scared stiff for my first flight in the RS. Regards, -Doug |
Negative flaps for better low speed aileron control? | [email protected] | Soaring | 41 | August 25th 05 06:01 AM |
f-84G Flaps question | Frederico Afonso | Military Aviation | 0 | September 8th 04 05:58 PM |
757 flaps miss-aligned in cruise | AnyBody43 | General Aviation | 1 | April 2nd 04 01:01 AM |
Cessna 182S flaps | EDR | Piloting | 7 | January 16th 04 02:37 AM |
Flaps and V-Tails of Death | Wallace Berry | Soaring | 59 | November 26th 03 09:54 PM |
