On Wed, 24 Aug 2005 16:59:30 -0500, Fly wrote:
Not often since I started using the 'airstop' tubes. Desser tires has the best deal. Kent Felkins From: "Jay Honeck" Subject: Flat Tires? Date: Wednesday, August 24, 2005 4:51 PM One of our least favorite jobs (thanks to our "Fancy Pants" with their stupid, under-sized access doors) is airing up the tires on our Pathfinder. I pull the plane back and forth while Mary fishes around for the stupid nipple. If you want to hear a woman cuss like a sailor, just stop by the hangar on tire-filling day! It seems like we're having to fill the tires way too often. At least every 3 - 4 weeks, we notice that the plane has become a real bear to pull out of the hangar, and that our take-off roll has become noticeably longer. Sure enough, the tires will be down around 25%, from 40 to 30 lbs on the mains, and from 30 to 23 lbs (or so) in the nosewheel. This seems ridiculous. Is it a product of tubed tires, or do I have slow leaks that should be fixed? Can you use "Fix-a-Flat" in aircraft tires? (I'll bet not.) How often do you guys have to fill your tires? Use lots of caution when using Fix-a-Flat. By design, the product is suppose to ONLY get you to a shop to get your tire repaired or replaced. Fix-a-Flat is VERY bad about putting tires out of balance. Their formula is also known to steadily destroy the rubber in which it remains in contact. I understand they have a newer formula out, which is said not to eat rubber, but the patch does not last anywhere near as long. Any any rate, Fix-a-flat, reguardless of the formula should never be thought of as anything other than a short-term fix. Long story short...use Fix-a-flat if you are stuck and have no other option. Otherwise, get the tire fixed or replaced before you need to use it. Greg |
I have small pant doors, too. Center the valve stem in the door opening
and yellow-chalk a line vertically from pant to floor on the tire. That makes it a one man job to locate the stem in the door opening. I use one of those small "picks" with a handle to bend the stem a little so I can do the inflation. Blue Skies 5217D HTH |
Flat Tires? | Jay Honeck | Owning | 40 | August 31st 05 01:59 AM |
Sources for retread tires?? | Jim Burns | Aviation Marketplace | 15 | November 24th 04 03:48 AM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Owning | 0 | March 20th 04 04:48 AM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Restoration | 0 | March 20th 04 04:48 AM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
