I put an RMI into our panel (a plug-in module for the Argus actually -
thanks Ebay) just for flying DME Arcs. What else are RMI's good for? The RMI has two needles, each of which can "point" to a navaid. As mentioned, this is good for identifying intersections (although I confess I prefer DME and one nav source). Better yet, you always know radial/bearing from/to a VOR/NDB. Good for locating yourself on the map or flying a missed approach when you need to "find the VOR" while climbing and turning. Just follow the needle. Personally, I'd invest in an HSI before I invested in an RMI. I'd invest in an Argus 7000 before I invested in an RMI (these things are amazing, and amazingly cheap these days - $700 on EBay right now). "Tom S." wrote in message ... When I quit flying some years back, RMI's were expensive and found generally only found in the "heavy metal". Now they seems quite common? What particular advantages do they offer? I can't find any good articles (other than marketing) on them. I was wondering if I should add one to a bird I plan to buy? Thanks |
![]() "McGregor" wrote in message ink.net... I put an RMI into our panel (a plug-in module for the Argus actually - thanks Ebay) just for flying DME Arcs. What else are RMI's good for? The RMI has two needles, each of which can "point" to a navaid. As mentioned, this is good for identifying intersections (although I confess I prefer DME and one nav source). Better yet, you always know radial/bearing from/to a VOR/NDB. Good for locating yourself on the map or flying a missed approach when you need to "find the VOR" while climbing and turning. Just follow the needle. Personally, I'd invest in an HSI before I invested in an RMI. I'd invest in an Argus 7000 before I invested in an RMI (these things are amazing, and amazingly cheap these days - $700 on EBay right now). All the aircraft I'm looking at have an HSI. The plane I fly with my boss has an RMI on his EFIS, but no on the co-pilot station. So far, we've never used it. I was wondering if I should add one to a bird I plan to buy? Thanks |
"Tom S." wrote in
: All the aircraft I'm looking at have an HSI. The plane I fly with my boss has an RMI on his EFIS, but no on the co-pilot station. So far, we've never used it. If you have an HSI, you certainly don't want to downgrade to an RMI. The HSI gives you much more information and is easier to interpret. -- Regards, Stan |
![]() "Stan Gosnell" me@work wrote in message ... "Tom S." wrote in : All the aircraft I'm looking at have an HSI. The plane I fly with my boss has an RMI on his EFIS, but no on the co-pilot station. So far, we've never used it. If you have an HSI, you certainly don't want to downgrade to an RMI. The HSI gives you much more information and is easier to interpret. Thanks, Stan. That's what I though, and I notice many of the more elaborate HSI's have RMI indicators. I'm just wondering what the big deal is in having both, as many aircraft do. My original point is that RMI's seem more common nowadays, but were somewhat rare when I began my hiatus from flying in 1989 (until this past summer). I was under the (mistaken??) assumption that they made NDB approaches easier. As I said, so far, I've not seen the boss use his. I would like to know the whys and HOW's in any case. Tom -- "Transported to a surreal landscape, a young girl kills the first woman she meets and then teams up with three complete strangers to kill again." --Marin County newspaper's TV listing for "The Wizard of Oz" |
was under the (mistaken??) assumption that they made NDB approaches easier. Yes, an RMI does make an NDB approach easier because an RMI shows easily and intuitively your bearing to an NDB. It works very similar to an ADF with a slaved rotating compass card. This means that applying wind correction on an NDB approach is much easier with an RMI. That said, I would not recommend investing money in an RMI right now. Not only can you get TWO electronic RMIs in a Sandel EHSI, but you can even set up a portable Garmin 195 or 295 or 196 GPS with a bearing pointer that functions as an RMI. If you have an IFR-legal ADF in your airplane, it is perfectly legal to fly an NDB approach while you supplement your ADF navigation with RMI information from your portable GPS -- just be sure your ADF remains your primary navigational source. -- Richard Kaplan, CFII www.flyimc.com |
![]() "Richard Kaplan" wrote in message m... "Tom S." wrote in message ... was under the (mistaken??) assumption that they made NDB approaches easier. Yes, an RMI does make an NDB approach easier because an RMI shows easily and intuitively your bearing to an NDB. It works very similar to an ADF with a slaved rotating compass card. This means that applying wind correction on an NDB approach is much easier with an RMI. That said, I would not recommend investing money in an RMI right now. Not only can you get TWO electronic RMIs in a Sandel EHSI, but you can even set up a portable Garmin 195 or 295 or 196 GPS with a bearing pointer that functions as an RMI. Plane I look to buy has an HSI already (King 150 AP/FD), but I was thinking of replacing the ADF indicator with a dual-needle RMI. Also, it's going to get a Garmin 530 ro replace the King Loran (not much use out here in the west). If you have an IFR-legal ADF in your airplane, it is perfectly legal to fly an NDB approach while you supplement your ADF navigation with RMI information from your portable GPS -- just be sure your ADF remains your primary navigational source. What does the ADF have to be the primary? Thanks!! Tom -- DeBeers ad's through the years: "A Diamond is forever!" then: Diamonds - Take her breath away!! Then again: Diamonds - Render her speechless! Why don't they just say it: Diamonds - That'll shut her up! |
