New Powerplant
Old August 26th 05, 01:03 AM
Bill Daniels
"Pete S" wrote in message
The August issue of AOPA PILOT reports a "tiny jet engine" is being
developed with 150 lbs of thrust. Its 15" long, 8.6" in diameter and
weighs 19 lbs. I wonder what it costs? This sounds like a great power
to weight ratio.
It is, but what you gain from the engine you loose from the amount of fuel
yoo have to carry. Take a look at www.microjeteng.com for what's available
now. I seem to recollect that a video was published on the internet of a
glass glider with a pop out pod with two jets on it.
Peter
Originally, I thought the horrible specific fuel consumption would make
these 'dog whistles' unsuitable for glider use.
On second thought, the residual weight after all the fuel is burned is much
less than a piston engine and propeller. The extend/stow mechanism is much
simpler as well. If they were used only for self launch and the entire fuel
supply were to be consumed in that launch, the idea has merit.
One worrisome issue is the temperatures of the tail surfaces that are in
contact with the jet exhaust. Bob Carlson told me that the fin on his jet
"Silent" reached 140F during the engine run even with two small turbojets
canted slightly outward to spare the fin. I suppose it's possible to choose
resins and curing processes that would make those fin temperatures
tolerable.
I have to admit that I like Bob Carlson's idea that if the ballast tanks
were to be filled with Jet A instead of water and then when in trouble just
start the jet and fly home instead of dumping ballast. My Nimbus would hold
75 gallons of Jet A which is several hours of engine run.
Bill Daniels
Old August 26th 05, 01:20 AM
01-- Zero One
140 degrees? Hell, sounds like Uvalde in August. Or Phoenix. I
wouldn't worry too much about it.
Larry
"Bill Daniels" wrote in message
to weight ratio.
Peter
tolerable.
Bill Daniels
Old August 29th 05, 10:44 PM
titoa
I had a look at the microjet engine. With 65 Lb of thrust, and with 36
cm long, 16 cm diameter, a 400 Kg plane should be able to climb at 1,3
m/s sustained (25 Lb for the aero drag, rest for climbing). Going to
1000 m would take just 12 mins and 11 Kg of fuel. I ignore the cost of
fuel, but at 1 $ /kg, that makes for cheap tows to offset the cost of
the engine.
Next, could the exhaust temperature be solved by embedding the tiny
engine behind the pilot and letting the exhaust out throug some
openning in the aft taper of the fuselage, and well below the tail
planes. This would however need some adjustable intake port in the
fuselage. But in all cases it should all be much simpler that folding
out a propeller with or without a piston engine.... .
Old August 30th 05, 02:10 AM
M B
The biggest issue against these engines is the TBO.
The AMT 45lbs engines are 25-50 hours for TBO.
Not bad in 20 minute spurts, but 160 launches
for $4000 just in engine costs ain't chicken feed.
$25 per launch? Good, but not fantastic. And for
2 of them
maybe a bit more... Still, glider self-launch seems
like a much better GA application than many other
options...
thrust, and with 36
to climb at 1,3
Going to
ignore the cost of
offset the cost of
the engine.
the tiny
throug some
below the tail
port in the
that folding
Mark J. Boyd
Old August 31st 05, 04:08 AM
Bob C
Time to weigh in with some facts.
First, for those who are skeptical of the jet Silent's
self-launch capabilities, I can assure you that I routinely
launch from my home airport at 6200' MSL. Ask anyone
who saw the demonstration during the 1-26 Nationals
this year. Granted, on hot days it does use some runway.
I have performed jet-launched aerobatic routines
at several airshows this summer, including full aerobatic
routines beginning at less than 1000'.
Noise has not been a problem. In fact, in the airshow
business, where noise equals dollars, the jets are
a bit too quiet. At 1000', they are MUCH less noisy
than any towplane. In fact, when I'm on a normal downwind,
the guys on the ground can't distinguish the jet noise
from the noise of the highway about 3 miles from the
airport.
TBO times are currently low, but an overhaul costs
about $300 (typically just inspection and new bearings).
These are NOT 'throwaway' engines. The engines can
be removed in about 15 minutes, and overnight shipped
back to the factory in a breadbox. My overhauls cost
less than the shipping for most powerplants. TBO times
are getting better as the engines develop. I predict
TBO times in the 100-200 hour range within a few years,
and over 1000 hours in the not-too-distant future.
Fuel burn is high, but for the brief time required
for a normal glider launch, tolerable. I carry 10
gallons, good for over 30 minutes of climb, or more
than 1 hour at 70 knot cruise. (I climb about 500
ft/minute at sea level)
There are other engines 'under development' with better
predicted performance numbers than the AMT-USA engines.
Some of these are garage-shop projects, some (including
one being advertised by a prominent US sailplane dealer)
are probably currently nothing more than plans and
a mockup. I do not know of any other microjet engine
currently available that has the performance, reliability
and factory support required for regular service in
a manned aircraft.
I know of several university projects in which a jet
assisted sailplane has been flown. Typically, these
have managed to barely sustain level flight under power,
and are a far cry from a serviceable aircraft.
Jet engines are not a 'perfect' answer. Like the early
military jets, there are still issues to be resolved.
But, in the next few years, microjets will definitely
play an important role in all aspects of sport aviation.
Videos of the jet sailplane, Salto sailplane and biplane
are available on my website at www.silentwingsairshows.com
Bob Carlton
2 of them
options...
thrust, and with 36
to climb at 1,3
Going to
ignore the cost of
offset the cost of
the engine.
the tiny
throug some
below the tail
port in the
that folding
Mark J. Boyd
Old August 31st 05, 04:49 AM
M B
I was unaware that overhauls were so very inexpensive.
I assumed the worst case, and am happy
this is unneccessary.
Thank you Bob for setting the record straight here.
Plus, thank you for doing this AT ALL.
I think you are definitely raising awareness of this
technology,
and have completely followed through on FAA
issues and have a better handle on this technology
as it applies to sailplanes than anyone else I have
encountered.
My only deep regret is that your airshow performances
are not scheduled in Calif. But I am glad many others
in the soaring community have had the privilege to
see you perform.
Your logged hours and experience go a LONG way towards
proving the viability of this technology. Thank you!
airport.
a manned aircraft.
Bob Carlton
2 of them
options...
thrust, and with 36
to climb at 1,3
Going to
ignore the cost of
offset the cost of
the engine.
the tiny
throug some
below the tail
port in the
that folding
Mark J. Boyd
Mark J. Boyd
Old August 31st 05, 08:18 PM
Andreas Maurer
On 31 Aug 2005 03:49:38 GMT, M B
Shall we bet that the overhaul is going to become expensive once the
engine is certified as a powerplant for certified gliders?
Bye
Andreas
Engine ( A-65) Propstrike and rebuild on cheap??? [email protected] Home Built 14 August 15th 05 02:59 PM
