On Thu, 25 Aug 2005 02:39:58 UTC, "Sandy Stevenson"
wrote: : I've gathered : that : it's related to lateral stability, and that the wings are not stalled, but I : don't yet : understand how it comes about that adding back pressure increases one's : airspeed. When a glider is turning it is simultaneously pitching and yawing. A flat turn is entirely yaw and a 90 degree bank turn is entirely pitch. The elevator controls the pitch, which is why you need more back pressure in steeper turns. If the turn is less than 90 degrees bank. pitching more also keeps the nose up, so the normal pull back - slow down relationship holds. If the turn is at more than 90 degrees, pitching more directs the flight path down more, so you speed up as you pull back. Ian |
Similar Threads | ||||
Paraglider spiral dive, throws chute and ends up in the trees | Stewart Kissel | Soaring | 8 | March 1st 05 10:04 PM |
inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 03:32 PM |
Fuel injection explanation | [email protected] | Piloting | 18 | June 23rd 04 02:57 AM |
