![]() Roger wrote: On Mon, 22 Aug 2005 18:06:14 -0700, Scott Moore wrote: snip I disagree. A battery backed up electric AI is not cheap, but compared to all of the components in a full vac system, it is, and its far more reliable. Even HAVING a current VAC system does not eliminate that cost, since the MTBF for a vac pump is down below 1000 hours, meaning you are going to have to change it soon in any case. Mine has a couple thousand on it and is still going strong. Do you have a wet pump? I would not fly hard IFR with a dry pump with much over 500 hours, and I do have a standby vac. The "M" in MTBF means half of the pumps last longer than that time, but it also means half lasted less. If the ceilings are 1000' I'm not rolling those dice. -cwk. |
Wet vs Dry Vacuum Pump | Fastglasair | Owning | 7 | December 17th 04 11:46 PM |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Backup vacuum pump system STC'ed for Cherokee 180 | Chuck | Owning | 6 | September 18th 04 02:30 PM |
Reverse Vacuum Damging to Instruments? | O. Sami Saydjari | Owning | 8 | February 16th 04 04:00 AM |
Can vacuum AI be removed if a certified electric one is installed?? | Dave | Owning | 11 | January 12th 04 06:08 PM |
