Grob G102 Setup
Old August 29th 05, 12:52 AM
HL Falbaum
If everythig is alined and it won't go in, the front and rear drag pins need
more grease! The swivelling pins with the groove on them have a very short
and steep taper, and the spring fingers inside the receptacle on the fuse
are strong. A good viscous grease like wheel bearing grease works better
than white lithium. My new favorite (Thanks Larry "01") is Radio Shack
lubricating gel. I have not tried STP or Motor Honey but they might work
even better. They are liquid and harder to handle though. The part about
centering the right spar in the left spar box opening is critical.
Perfect practice makes perfect performance--
Best of luck
HL Falbaum
"BDS" wrote in message
"Chris Reed" wrote in message
We do check all the pins and their mating bushings before trying to get
them
to mate. The frustrating thing is that they all look just fine but the
wing
will still refuse to go in. I have tried (due to frustration) to wiggle
wing fore and aft and up and down but that never helps at all
BDS
Old August 29th 05, 01:44 AM
Frank Whiteley
Cleaning and greasing help a lot, or did with our G-103. Once we got
our trailer more user friendly, a few people started landing out.
Interesting how easy it got to rig and derig once cleaned up and lubed.
Frank Whiteley
Glider Independent Palm Nav Setup John Doe Soaring 5 April 8th 05 04:58 PM
Grob 102 AD superseded Jim Phoenix Soaring 3 September 15th 04 01:40 AM
Help with Grob Needed Scott Soaring 5 January 11th 04 05:07 AM
Help, Need Complete Front Canopy for Grob 103 Carl Buehler Soaring 0 December 28th 03 02:15 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
