This website gives quite an interesting history of Kamov who have been
making co-axials for many years http://avia.russian.ee/vertigo/peopl...v/index_2.html and are the makers of this latest one. On this latest single place the lower swashplate is visible in some photos and it looks like the pitch arms for the upper rotor go down the center of the main shaft. Regards Peter "Stuart & Kathryn Fields" wrote in message ... Very interesting. I can't see any pitch control linkage to the blades. Don't read Russian, but do they say anything about autorotation? -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 (760) 408-9747 general and layout cell (760) 608-1299 technical and advertising cell www.vkss.com www.experimentalhelo.com "Blue" wrote in message u... Interesting new co-axial from Russia. Not too much info yet as it is a prototype. However all static and ground tests made, flying time only 12 hours. More info will be available after all tests. Check out these web sites for info. http://www.airtrikes.net/heli.jpg http://delta.wtr.ru/wtboard/40671.shtml www.clubrotor.ru |
Peter Seddon wrote:
This website gives quite an interesting history of Kamov who have been making co-axials for many years http://avia.russian.ee/vertigo/peopl...v/index_2.html and are the makers of this latest one. On this latest single place the lower swashplate is visible in some photos and it looks like the pitch arms for the upper rotor go down the center of the main shaft. Regards Peter "Stuart & Kathryn Fields" wrote in message ... Very interesting. I can't see any pitch control linkage to the blades. Don't read Russian, but do they say anything about autorotation? I don't see any evidence of pitch links at all, unless they are hydraulic, with rotating hydraulic joints, hydraulic tubes inside the shafts, and very small actuators. For autorotation, it could use engine torque actuated linkages to adjust collective for autorotation. If engine torque goes to zero, pitch goes to negative, pilot alarm is momentary negative gees and imposed descent - forced autorotation on power loss. I suggested such an idea several years ago on this forum. You don't think they stole my idea? Or maybe they adjust pitch by moving the relative position of three concentric rotating shafts up and down a half inch or so? There might not be any cyclic control at all. Why not? Yaw control by differential rotor torque and tailfin in downwash / slipstream? Now, if it was only quiet enough to tolerate in your back yard, everyone would want one. The tranny design is a doddle kept secret by commercial mil / ind complex, its an automotive differential, with one half turned inside out. Terry K |
This was the pic that made me think the pitch links go down the main shaft
for the top rotor. http://www.clubrotor.ru/album/gel8.jpg The pic also shows the botton swash and pitch links. All the kamaov machines that I have seen on their webiste have both rotors controlled by pitch links. Regards Peter "Terry Spragg" wrote in message ... Peter Seddon wrote: This website gives quite an interesting history of Kamov who have been making co-axials for many years http://avia.russian.ee/vertigo/peopl...v/index_2.html and are the makers of this latest one. On this latest single place the lower swashplate is visible in some photos and it looks like the pitch arms for the upper rotor go down the center of the main shaft. Regards Peter "Stuart & Kathryn Fields" wrote in message ... Very interesting. I can't see any pitch control linkage to the blades. Don't read Russian, but do they say anything about autorotation? I don't see any evidence of pitch links at all, unless they are hydraulic, with rotating hydraulic joints, hydraulic tubes inside the shafts, and very small actuators. For autorotation, it could use engine torque actuated linkages to adjust collective for autorotation. If engine torque goes to zero, pitch goes to negative, pilot alarm is momentary negative gees and imposed descent - forced autorotation on power loss. I suggested such an idea several years ago on this forum. You don't think they stole my idea? Or maybe they adjust pitch by moving the relative position of three concentric rotating shafts up and down a half inch or so? There might not be any cyclic control at all. Why not? Yaw control by differential rotor torque and tailfin in downwash / slipstream? Now, if it was only quiet enough to tolerate in your back yard, everyone would want one. The tranny design is a doddle kept secret by commercial mil / ind complex, its an automotive differential, with one half turned inside out. Terry K |
Peter: Thanks, that picture definitely shows the pitch links on the top
blades. However, look at the mass of engine and transmission mounted so high. To avoid a nose-over, all slide on landings should be conducted either on ice or a teflon coated airstrip. Alternatively the skids should be extended out front considerably farther...Dynamic roll overs should be a lot easier in this bird also. That said, I wish them luck in developing their pretty bird.. I will definitely have a mention in the next magazine and use this photo. Thanks -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 (760) 408-9747 general and layout cell (760) 608-1299 technical and advertising cell www.vkss.com www.experimentalhelo.com "Peter Seddon" wrote in message ... This was the pic that made me think the pitch links go down the main shaft for the top rotor. http://www.clubrotor.ru/album/gel8.jpg The pic also shows the botton swash and pitch links. All the kamaov machines that I have seen on their webiste have both rotors controlled by pitch links. Regards Peter "Terry Spragg" wrote in message ... Peter Seddon wrote: This website gives quite an interesting history of Kamov who have been making co-axials for many years http://avia.russian.ee/vertigo/peopl...v/index_2.html and are the makers of this latest one. On this latest single place the lower swashplate is visible in some photos and it looks like the pitch arms for the upper rotor go down the center of the main shaft. Regards Peter "Stuart & Kathryn Fields" wrote in message ... Very interesting. I can't see any pitch control linkage to the blades. Don't read Russian, but do they say anything about autorotation? I don't see any evidence of pitch links at all, unless they are hydraulic, with rotating hydraulic joints, hydraulic tubes inside the shafts, and very small actuators. For autorotation, it could use engine torque actuated linkages to adjust collective for autorotation. If engine torque goes to zero, pitch goes to negative, pilot alarm is momentary negative gees and imposed descent - forced autorotation on power loss. I suggested such an idea several years ago on this forum. You don't think they stole my idea? Or maybe they adjust pitch by moving the relative position of three concentric rotating shafts up and down a half inch or so? There might not be any cyclic control at all. Why not? Yaw control by differential rotor torque and tailfin in downwash / slipstream? Now, if it was only quiet enough to tolerate in your back yard, everyone would want one. The tranny design is a doddle kept secret by commercial mil / ind complex, its an automotive differential, with one half turned inside out. Terry K |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Lockheed wins Presidential helicopter contract | Tiger | Naval Aviation | 0 | January 29th 05 05:24 AM |
Musings of a Commercial Helicopter Pilot | Badwater Bill | Home Built | 6 | February 27th 04 09:11 AM |
Musings of a Commercial Helicopter Pilot | Badwater Bill | Rotorcraft | 0 | February 25th 04 06:39 PM |
Helicopter crash video | James Blakely | Piloting | 17 | December 30th 03 03:21 PM |
