Ok, a question or 2 about the wings. I'm building a wooden aircraft
that could go either fixed tri-gear or retract. I choose fixed seeing how this is my first plane to build and I wanted to keep it simple. The fuel was supposed to go behind the firewall but I choose to build tanks in each wing where the wheels where to go. What will this do to the loading of the aircraft? Does this effect the useful load and how? Does it raise my useful load or lower it or niether? Since the wings create lift, and the fuel was in the fuselage and now in the wing should it screw up the center of gravity? Anybody, Anybody, Anybody???? |
Lou wrote:
Ok, a question or 2 about the wings. I'm building a wooden aircraft that could go either fixed tri-gear or retract. I choose fixed seeing how this is my first plane to build and I wanted to keep it simple. The fuel was supposed to go behind the firewall but I choose to build tanks in each wing where the wheels where to go. What will this do to the loading of the aircraft? Does this effect the useful load and how? Does it raise my useful load or lower it or niether? Since the wings create lift, and the fuel was in the fuselage and now in the wing should it screw up the center of gravity? Anybody, Anybody, Anybody???? Depends upon the wing and where in the wing the tanks are located. Fuel burn will affect center of gravity. Tank shape and location will determine the affect. |
Lou wrote:
Ok, a question or 2 about the wings. I'm building a wooden aircraft that could go either fixed tri-gear or retract. I choose fixed seeing how this is my first plane to build and I wanted to keep it simple. The fuel was supposed to go behind the firewall but I choose to build tanks in each wing where the wheels where to go. What will this do to the loading of the aircraft? Does this effect the useful load and how? Does it raise my useful load or lower it or niether? Since the wings create lift, and the fuel was in the fuselage and now in the wing should it screw up the center of gravity? Anybody, Anybody, Anybody???? Well, I'm not really an expert... but by moving the tank(s) from behind the firewall to the wings, you create two main issues: First, center-of-gravity changes. Moving them further aft will cause an aft shift in CG. You will have to move other components forward to compensate (or add ballast), and be VERY, VERY sure you analyze all of the load conditions possible to make sure the CG is not out-of-limits. Second, moving the tanks to the wings (assuming a low-wing aircraft) means you will need an engine-driven fuel pump and an electric boost pump. You can't simply use a gravity feed like you could with high-wing tanks or (I'm assuming) a fuselage-mounted tank. As far as changes in lift, assuming you don't change the outer mold line of the wing, you won't generate more or less lift by putting the tanks in the wing. However, putting them out there means the load distribution will change; you have to make sure your wing structure can support the tank. However, moving the tanks to the wings should reduce the bending moment a bit. |
Lou wrote:
Ok, a question or 2 about the wings. I'm building a wooden aircraft that could go either fixed tri-gear or retract. I choose fixed seeing how this is my first plane to build and I wanted to keep it simple. The fuel was supposed to go behind the firewall but I choose to build tanks in each wing where the wheels where to go. What will this do to the loading of the aircraft? Does this effect the useful load and how? Does it raise my useful load or lower it or niether? Since the wings create lift, and the fuel was in the fuselage and now in the wing should it screw up the center of gravity? Anybody, Anybody, Anybody???? You have to worry about 3 axis. With now knowledge of the airplane, it is possible that the fuels position may not have not changed fore or aft. If that it true then your CG is safe. If not, then you will have to be very careful in your weight and balance calculations. The nice thing about wing tanks is that the fuel tends to sit on the center of lift. When this is the case, the draining fuel doesn't cause your trim to creep. Next is the vertical axis. If you move a lot of weight from up high to down load, but leave the center of thrust untouched, then you've created a situation where adding thrust will cause the plane to tend to nose over. You're trying to move a filing cabinet by pushing the top. So, you're on short final, just before the flair, all trimmed out and smooth. A deer jumps on the runway. You firewall the throttle. Do you have enough elevator to keep from eating a mouthful of dirt. The other issue is lateral loading. Move all that weight to the wings and you've modified your roll response. Just like an ice skater that changes her spin by extending her arms or retracting her arms (moving weight in and out.) When you try to start a roll, you have to have enough differential lift in the ailerons to get everything moving...and THEN get everything stopped. Moving the tanks could make the plane difficult to control. The upshot is that the wing ROOT doesn't have to carry the bending moment of the fuel load. If the wing root was the limiting factor in your load allowance, then this move very well could increase your plane's usefull load. Airplanes have to be light, though. It's doubtful that the designer cut the wing root to the bare minimum and then beefed up everthing else, like landing gear, tail surface area, elevator surface area, etc. I wouldn't bet MY life on an increased load allowance from moving the fuel tank. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Very nice analogie's, they put good pictures in my head. If I kept the
fuel tank in the fuselage behind the firewall, wouldn't that have created trim problems as the fuel got used up? |
Lou, have you asked tjis question to the designer of your craft?
His comments could be very interesting and informative. Jean-Paul "Lou" wrote in message oups.com... Very nice analogie's, they put good pictures in my head. If I kept the fuel tank in the fuselage behind the firewall, wouldn't that have created trim problems as the fuel got used up? |
As a matter of fact I finally found a way to communicate with him. He
is an Italian resident who doesn't speak english and I could so much as insult someone in Italian. I did get a fax number for him (I will find out about email soon) and am starting to translate a bunch of questions to fax him. This will be interesting. |
Bending loads on the spar will be less if tanks are wing mounted, because
the lift from the wings acts directly on the mass of the fuel. It has to do with the concept of load path -- when a laod is applied to the airplane at any point other than the CG, the load must get to the CG through the structure of the airplane. That's why the Questair Venture has its nosegear attached to the engine instead of the airplane, because it is always advantageous to feed loads directly into a major mass. Regards, Gordon. PS: What design are we talking about? "Ernest Christley" wrote in message . com... Lou wrote: Ok, a question or 2 about the wings. I'm building a wooden aircraft that could go either fixed tri-gear or retract. I choose fixed seeing how this is my first plane to build and I wanted to keep it simple. The fuel was supposed to go behind the firewall but I choose to build tanks in each wing where the wheels where to go. What will this do to the loading of the aircraft? Does this effect the useful load and how? Does it raise my useful load or lower it or niether? Since the wings create lift, and the fuel was in the fuselage and now in the wing should it screw up the center of gravity? Anybody, Anybody, Anybody???? You have to worry about 3 axis. With now knowledge of the airplane, it is possible that the fuels position may not have not changed fore or aft. If that it true then your CG is safe. If not, then you will have to be very careful in your weight and balance calculations. The nice thing about wing tanks is that the fuel tends to sit on the center of lift. When this is the case, the draining fuel doesn't cause your trim to creep. Next is the vertical axis. If you move a lot of weight from up high to down load, but leave the center of thrust untouched, then you've created a situation where adding thrust will cause the plane to tend to nose over. You're trying to move a filing cabinet by pushing the top. So, you're on short final, just before the flair, all trimmed out and smooth. A deer jumps on the runway. You firewall the throttle. Do you have enough elevator to keep from eating a mouthful of dirt. The other issue is lateral loading. Move all that weight to the wings and you've modified your roll response. Just like an ice skater that changes her spin by extending her arms or retracting her arms (moving weight in and out.) When you try to start a roll, you have to have enough differential lift in the ailerons to get everything moving...and THEN get everything stopped. Moving the tanks could make the plane difficult to control. The upshot is that the wing ROOT doesn't have to carry the bending moment of the fuel load. If the wing root was the limiting factor in your load allowance, then this move very well could increase your plane's usefull load. Airplanes have to be light, though. It's doubtful that the designer cut the wing root to the bare minimum and then beefed up everthing else, like landing gear, tail surface area, elevator surface area, etc. I wouldn't bet MY life on an increased load allowance from moving the fuel tank. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Lou wrote:
Very nice analogie's, they put good pictures in my head. If I kept the fuel tank in the fuselage behind the firewall, wouldn't that have created trim problems as the fuel got used up? If you move any loads, including the fuel, you've changed the trim point. You're always chasing the trim to some small extent anyway (unless you have an autopilot which is doing the chasing for you). I don't know if it can be described as a problem. You, as the pilot, will have to decide that. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ok I've started it, I have built the 2 wing ribs the way it called for
in the plans if I were installing the retract gear. The only differnce is that I will not be cutting the bottom of the ribs out for the gear that won't be there. They seem to be extreemly strong, sorry I didn't think of this for luggage. Lou |
Long wing twisting | JJ Sinclair | Soaring | 13 | June 28th 05 06:42 PM |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
