Garmin 396 'installation' in the Maule
Old August 30th 05, 11:41 AM
Maule Driver
Well, it definitely can sit up there in the tubing crotch, well clear of
cables, etc. But it definitely won't be removeable.
I'm now looking at just laying it on the floor in the baggage area and
stringing the cable along the floor. The extension plug will end up
right under my seat. The question I haven't answered yet is whether it
will receive well from there but I think it might given the extensive
composite construction on the Maule (composite = tubing, sheet metal,
fabric, and glass :-) )
George Patterson wrote:
Maule Driver wrote:
It seems to work just fine up there thru fabric and insulation -
perfect! I can get as far away from the compass as the cable allows.
Looks like the magnet naturally finds a crotch a in the tubing to
magnetize itself too.
Great! Just keep it away from the aileron cables.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old September 1st 05, 02:33 PM
Maule Driver
Further testing shows the floor doesn't work. Back to the tubing crotch.
BTW, I tried and rejected the yoke mount. It places the display to
close to my eyes compared to the rest of the panel (aging eyes). I
fabricated a bracket to hang it from the panel over the flap handle.
May be OK but taking a trip this weekend to test.
This is my first 'portable'. I am not happy with the wires and location
options. Definitely a compromise over panel mounts, but I guess that's
no surprise.
Old September 2nd 05, 03:24 AM
George Patterson
Try putting it high behind the rear bulkhead. You'll be able to get it out
easily, but it might work better there. Michelle has her ELT back there. If it
works well, you could screw a metal plate onto the rear bulkhead (above the
removable part) and attach it to that with the magnet.
George Patterson
Old September 6th 05, 04:11 PM
Maule Driver
Well, I ended up with it in the overhead crotch. I might stay with that
awhile until I figure out how much I'll want to remove it for land use.
Turns out that it can easily and securely be popped in and out right
thru one of the the headliner zippers and I just let the cable hang. OK
for now.
I'll have to write a trip report for the weekend. What a machine!!
out easily, but it might work better there. Michelle has her ELT back
there. If it works well, you could screw a metal plate onto the rear
bulkhead (above the removable part) and attach it to that with the magnet.
George Patterson
Old September 6th 05, 05:35 PM
George Patterson
You might consider buying another antenna for land use. IIRC, the price is about
$240.
George Patterson
Old September 6th 05, 05:56 PM
Jonathan Goodish
In article 8zjTe.15758$aG.13842@trndny01,
about
$240.
There's a catch: The 396 XM antenna is also the XM receiver. XM will
only allow one receiver to be assigned to each subscription.
JKG
Old September 6th 05, 07:06 PM
Maule Driver
I guessed that was the case.
Old September 2nd 05, 12:17 PM
Dan Luke
Trifocals.
I got my first pair eight years ago for precisely this reason. They're
perfect for flying. The bottom lens makes a yoke-mounted GPS clear, and
the middle lens is perfect for the panel (you can get the eye doc to
write the prescription for the distance you want).
Dan
C172RG at BFM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
