Flat Tires?
Old August 30th 05, 07:44 PM
RST Engineering
That wasn't the point, Orval. The original discussion revolved around the
tendency of most aircraft tubes to diffuse air through the walls of the
tube -- deflate themselves by spontaneous diffusion as it were. THe reason
given was that the specification for aircraft tubes uses a material that is
obsolete in the real world but still used in the make-believe world of
aviation.
Somebody brought up the point that Desser (via Michelin?) has come up with a
"no leak" tube that is blessed for aviation use. Some of the group on here
reported that the "no leak" was in fact just that and a few of the folks
plan on switching to that tube at the next opportunity.
(You left a B out of your signature line.)
"ORVAL FAIRAIRN" wrote in message
news
In article ikZQe.293072$_o.110885@attbi_s71,
"Jay Honeck" wrote:
Why not patch the tube? I have done it several times and have not
detected any problems. Just be sure to use the "hot patch" method.
Old August 31st 05, 01:59 AM
Roger
On Tue, 30 Aug 2005 11:44:23 -0700, "RST Engineering"
aviation.
They are called "Leak Guard". I thought I paid $12, but it was $28
each for 6.00 X 6 tubes through Desser.
When installing them you fit the tube into the tire with talcum powder
just like a regular ones. Line up the dots, bars, or what ever, toque
the bolts in the split rim, Inflate it, deflate it, and re inflate.
They aren't completely leak proof, but they hold air much longer than
the old tubes. I already mentioned they were only down 4 psi after 6
weeks.
www.rogerhalstead.com
Tires again (but this time on the tow vehicle) Papa3 Soaring 37 February 7th 05 02:30 PM
WTB: Good Set 500 x 5 Wheels, Tires and Brakes Steve Sharp Owning 0 March 20th 04 04:48 AM
WTB: Good Set 500 x 5 Wheels, Tires and Brakes Steve Sharp Restoration 0 March 20th 04 04:48 AM
Flat Spin JJ Sinclair Soaring 34 February 10th 04 05:57 PM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
