![]() wrote in message oups.com... "Gig 601XL Builder" wr.giacona@coxDOTnet wrote in message news:ed0Re.6670$7f5.4709@okepread01... The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. No, if the abolute odds of not surviving A jump are 1:10,000. The odds of death are 1:10,000 on jump #1,#2,...#10000... #20000. The dice don't have a memory. Yes, but a jumper *does* have a memory. A jumper cannot have a second jump *unless* the first jump was successful, correct? Above, I was comparing two jumpers, one who had 9999 jumps under his belt, and another who had 0 jumps under his belt. For the new jumper, his odds are 1:10,000 (if that is accurate) for his first jump. For the experienced jumper, his odds of surviving his *first* jump are 100%, since he already survived his first jump. It is no longer in the realm of "probability", it is now in the realm of certainty, since it is in the unchangeable past. To give another example that might make things more clear, suppose we have two people: 1) One person is going to take a revolver, put one bullet in the gun, and play "Russian Roulette" 1000 times. 2) A second person has already played (and survived) a game of Russian Roulette 999 times, and only has to play it for one more time. The second person has a 5/6 chance of survival. Do you honestly give the first person 5/6 chance of survival? I would give him (without calculating precisely) somwhere around 0.005 % chance of survival. There is a difference. The odds for an something to happen on any given roll,trigger pull or jump don't change |
news:Kx1Re.6675$7f5.2476@okepread01... The second person has a 5/6 chance of survival. Do you honestly give the first person 5/6 chance of survival? I would give him (without calculating precisely) somwhere around 0.005 % chance of survival. There is a difference. The odds for an something to happen on any given roll, trigger pull or jump don't change Yes, I'm aware of that. But we're not discussing an isolated instance. We are discussion a *sequence* of related incidents. Please see other replies in this thread. Btw, you didn't answer my question. Do you honestly believe that someone who starts from "zero state", and plays Russian Roulette with a 6-shooter, 1000 times, has a 5/6 chance of survival? If you do, you don't understand probability theory. -- Jeff Shirton jshirton at cogeco dot ca Keep thy airspeed up, lest the earth come from below and smite thee. - William Kershner Challenge me (Theophilus) for a game of chess at Chessworld.net! |
![]() wrote in message oups.com... "Gig 601XL Builder" wr.giacona@coxDOTnet wrote in message news:Kx1Re.6675$7f5.2476@okepread01... The second person has a 5/6 chance of survival. Do you honestly give the first person 5/6 chance of survival? I would give him (without calculating precisely) somwhere around 0.005 % chance of survival. There is a difference. The odds for an something to happen on any given roll, trigger pull or jump don't change Yes, I'm aware of that. But we're not discussing an isolated instance. We are discussion a *sequence* of related incidents. Please see other replies in this thread. Btw, you didn't answer my question. Do you honestly believe that someone who starts from "zero state", and plays Russian Roulette with a 6-shooter, 1000 times, has a 5/6 chance of survival? If you do, you don't understand probability theory. Of course not. I also don't expect to get a Royal Flush when the guy accross the table has 4-of-a-kind and a whole lot of chips but if I play poker long enough I might. |
Gig 601XL Builder wrote:
wrote in message oups.com... "Gig 601XL Builder" wr.giacona@coxDOTnet wrote in message news:ed0Re.6670$7f5.4709@okepread01... The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. No, if the abolute odds of not surviving A jump are 1:10,000. The odds of death are 1:10,000 on jump #1,#2,...#10000... #20000. The dice don't have a memory. Yes, but a jumper *does* have a memory. A jumper cannot have a second jump *unless* the first jump was successful, correct? Above, I was comparing two jumpers, one who had 9999 jumps under his belt, and another who had 0 jumps under his belt. For the new jumper, his odds are 1:10,000 (if that is accurate) for his first jump. For the experienced jumper, his odds of surviving his *first* jump are 100%, since he already survived his first jump. It is no longer in the realm of "probability", it is now in the realm of certainty, since it is in the unchangeable past. To give another example that might make things more clear, suppose we have two people: 1) One person is going to take a revolver, put one bullet in the gun, and play "Russian Roulette" 1000 times. 2) A second person has already played (and survived) a game of Russian Roulette 999 times, and only has to play it for one more time. The second person has a 5/6 chance of survival. Do you honestly give the first person 5/6 chance of survival? I would give him (without calculating precisely) somwhere around 0.005 % chance of survival. There is a difference. The odds for an something to happen on any given roll,trigger pull or jump don't change True, but that isn't the issue at hand. The issue is surviving a SERIES of future events, not just the next one. Matt |
Ten Years of Flying | Jay Honeck | Piloting | 20 | February 19th 05 02:05 PM |
How safe is it, really? | June | Piloting | 227 | December 10th 04 05:01 AM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
