![]() "Marty from Florida" marty@-x-x-x- remove -x-x- worth.net wrote in message ... ........... If anyone has a prop that would fit my 1982 C152 with a Lycoming 0-235/L2 engine, please let me know. I don't want to have to service a prop annually! Thanks again. Marty After reading what I think is the recurring AD for that prop, it's not necessarily an overhaul, but an inspection. It is to check for cracks at the bolt holes around the hub. This inspection is to be done every 800 hrs or 12 months, if it's OK the prop is painted and returned to service. The other AD (one-time) has to do with specific bolts and a spacer used to mount the prop. So you said it was $100 to r/r the prop? How much is a dye test for cracks? to paint? -- Hello, my name is Mike, and I am an airplane addict.... |
Mike,
Thanks for the comment. I'm pretty certain the one time AD for the bolt holes has been complied with, but I'll check to be sure (I've only had this 152 for a few months). The annual inspection was completed last year with a dye test for $ 52.00 from a mechanic who is 1,400 miles from where the plane now lives. I called a local shop, and was told a dye test involved 80% of a complete overhaul, in that the prop had to be pulled, scraped, tested, and re-painted. I'm confused about how someone could do this for $ 52.00, but I'm also in Palm Beach Florida, where dishonesty is only superseded by incompetence. (Sorry for the bitching, but I've been handed a lot of nonsense from professionals in my area). I had a new alternator installed by a very expensive shop, only to find the main harness and wires were pressed hard against an exhaust pipe. The reason I need an overhaul is not to comply with the AD, but because the prop is rough. No visible nicks or cracks, and it doesn't have any noticeable vibration, but the surface is anything but smooth. At annual, the IA said it needed an overhaul to be airworthy, and when I found out what it would cost to just sand and paint a prop, I was amazed. If any A&P's read this, please toss in an opinion. If anyone has a replacement Sensenich 72CKS6-0-56, please drop me an email. Marty "Mike W." wrote in message ... "Marty from Florida" marty@-x-x-x- remove -x-x- worth.net wrote in message ... .......... If anyone has a prop that would fit my 1982 C152 with a Lycoming 0-235/L2 engine, please let me know. I don't want to have to service a prop annually! Thanks again. Marty After reading what I think is the recurring AD for that prop, it's not necessarily an overhaul, but an inspection. It is to check for cracks at the bolt holes around the hub. This inspection is to be done every 800 hrs or 12 months, if it's OK the prop is painted and returned to service. The other AD (one-time) has to do with specific bolts and a spacer used to mount the prop. So you said it was $100 to r/r the prop? How much is a dye test for cracks? to paint? -- Hello, my name is Mike, and I am an airplane addict.... |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
my ignorance | LCT Paintball | Home Built | 25 | April 9th 05 06:54 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
Major Overhaul | Jim Weir | Owning | 10 | June 8th 04 05:12 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
