Mike Granby wrote:
I've had silly numbers (30+ hours) without the antenna, so perhaps it varies from unit to unit. Still, it's not a big deal. I'm planning to wire the unit into ship's power this weekend, so it'll be rather academic after that. As long as it can last long enough to get me somewhere safe if I lose electrical power, that's good enough. You probably already did this, but upgrade the firmware to 2.40 and try again. There's nothing specific in the release notes for 2.40 indicating a power management-related fix (and I didn't bother to read back to the notes on the previous versions), but it shouldn't hurt to upgrade. If the problem persists the battery is likely at fault, as it contains logic to transmit the state of the battery to the GPS firmware. The GPS firmware, then, merely reports what it's being told. Try to borrow someone else's battery and see if the problem goes away. -Doug -- -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
![]() Good points, Doug. I'll try the firmware, and if that doesn't fix it, no big deal. I notice, too, that the firmware notes mention an improvement to Aviation In format. I'm hoping that fixes the CR vs. CR-LF issue I've discovered that prevents use with King panel-mount GPSs. That'll save me some work... |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
