And remember, there is an absolutely wonderful and free calibration point at
212°F available for nothing more than a pan of water and a hotplate. Jim wrote in message ... Remember, this advice is worth exactly what you paid for it... TC |
RST Engineering wrote:
And remember, there is an absolutely wonderful and free calibration point at 212°F available for nothing more than a pan of water and a hotplate. If you're at sea level. If your elevation is substantially different from that, you need to look up the boiling point of water. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
But I think the width of the needle of our gauge will compensate for that.
It's an old style gauge with only a dot at 200F and the next dot is at 400F. The best we can do is try to keep the needle below the 400F dot a tad. I guess we could also calibrate it with a pan of oil, a hot plate, and a candy thermometer. Jim "George Patterson" wrote in message news:cgvRe.12917$LK.8705@trndny09... RST Engineering wrote: And remember, there is an absolutely wonderful and free calibration point at 212°F available for nothing more than a pan of water and a hotplate. If you're at sea level. If your elevation is substantially different from that, you need to look up the boiling point of water. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
I
guess we could also calibrate it with a pan of oil, a hot plate, and a candy thermometer. RIght on! This is the sort of thing that is taught in high school physics (or was, in my day, right after the earth first cooled) denny |
BTW, that 82 ohm power resistor (??) you need is available at www.mouser.com
5 watt cement coated fireproof resistors (280 CR5 series) are 39 cents in onesies. 3 watt flame retardant resistors (283 series) are also 39 cents in onesies. Mouser has no minimum order and a decent shipping policy. Somebody needs to measure the current that these things are sucking. In order to dissipate 1 watt in an 82 ohm resistor, you need a bit more than 100 mA (0.1 amps) to flow. My gut says that this is not happening. Jim "Jim Burns" wrote in message ... But I think the width of the needle of our gauge will compensate for that. It's an old style gauge with only a dot at 200F and the next dot is at 400F. The best we can do is try to keep the needle below the 400F dot a tad. I guess we could also calibrate it with a pan of oil, a hot plate, and a candy thermometer. |
Thanks Jim, I appreciate the link.
I also found some 82ohm 2W 5% flameproof resistors on ebay. Some more goggling found that this Rochester probe w/82ohm resistor "work around" has been used by owners of Pipers, Bonanzas and Commanders, all with the AC Spark Plug CHT gauge. The 82ohms is the one constant in everything I've read, the W varied between 2 and 3Watts and the tolerance was either 2 or 5%. Not having a background in electronics, what ultimate difference would a resistor of higher wattage rating have on the circuit, the gauge, or the probe? If the circuit is only drawing mA's, 1) are there "smaller" mA rated 82ohm resistors available or 2) with a mA rated resistor would the required ohm rating change? Forgive my ignorance regarding resistors, I basically understand what they do, but do not know the implications of the sizes/capacities. I'm just looking for a way to get out of several hours of tedious PITA work with my upper torso stuffed up underneath our panel. Instrument Tech of Dallas TX seems to have quite a bit of experience with the combo and emailed me the American Bonanza Society newsletter that contains the article. The original question was published June 1990, and the explanation and work around was published some time shortly after however I do not have that date. Jim "RST Engineering" wrote in message ... BTW, that 82 ohm power resistor (??) you need is available at www.mouser.com 5 watt cement coated fireproof resistors (280 CR5 series) are 39 cents in onesies. 3 watt flame retardant resistors (283 series) are also 39 cents in onesies. Mouser has no minimum order and a decent shipping policy. Somebody needs to measure the current that these things are sucking. In order to dissipate 1 watt in an 82 ohm resistor, you need a bit more than 100 mA (0.1 amps) to flow. My gut says that this is not happening. Jim "Jim Burns" wrote in message ... But I think the width of the needle of our gauge will compensate for that. It's an old style gauge with only a dot at 200F and the next dot is at 400F. The best we can do is try to keep the needle below the 400F dot a tad. I guess we could also calibrate it with a pan of oil, a hot plate, and a candy thermometer. |
Jim Burns wrote:
Not having a background in electronics, what ultimate difference would a resistor of higher wattage rating have on the circuit, the gauge, or the probe? If the circuit is only drawing mA's, 1) are there "smaller" mA rated 82ohm resistors available or 2) with a mA rated resistor would the required ohm rating change? Forgive my ignorance regarding resistors, I basically understand what they do, but do not know the implications of the sizes/capacities. I don't have a background in electronics, either, but I'd think 3 watts is way overkill from an electrical point of view, *but* a higher power rated resistor is also more robust from a mechanical point of view, and may stand up better to the vibration environment. Just an idea from an ignorant observer. Dave |
![]() I don't have a background in electronics, either, but I'd think 3 watts is way overkill from an electrical point of view, *but* a higher power rated resistor is also more robust from a mechanical point of view, and may stand up better to the vibration environment. Just an idea from an ignorant observer. Dave You summed up my thinking pretty close. I'm thinking if 3W is overkill, what are the downsides of it? Shorter probe life? shorter gauge life? shorter resistor life? If it doesn't detrimentally effect the operation of either the probe or the gauge and the life of the components isn't compromised, then the only downside I see is about $0.10. But like I said, I don't have much knowledge in this area but I'm willing to learn so I defer to the pros. Thanks Jim |
As long as the higher wattage resistor fits physically and is the
appropriate resistance (82 ohms in this case), it will work just fine... It will be just loafing at a small fraction of a watt and so should never 'burn out from thermal stress.... Physically larger is usually more mechanically robust, as Dave surmises... Resistors start at 1/8 watt at most electronic suppliers and go up into the hundreds of watts... The larger units will not be available in all resistances, especially in the megohm range... For what you need it in the airplane, a wirewound "flameproof" of 2 watts is fine... denny |
Jim ...
The three main resistor characteristics are value (ohms), tolerance (%), and power handling capability (watts). There are other second-order effects, but let's not worry about them right now. You've got the value nailed. You've got the tolerance pretty well in hand. Tolerance is pretty much linear with dollars. That is, a 5% resistor might cost a dime. A 0.5% resistor may cost a dollar. A 0.05% resistor might be $10, and so on. For your "hammer, file, kick in the edges and weld shut" project 5% is well within any reasonable design consideration. Wattage is a little like a wooden deck. A fly lands on it, no big deal. You drive a motorcycle on it and it may groan, but will probably not break. Drive a HummV on it and you've got matchsticks. Ohm told us that the power dissipated in a resistor is equal to the current through the resistor (squared) times the resistor value (P = I^2 * R). Let's say, just for grins, that the current through the resistor is 10 mA (ten milliamperes) or so. This 82 ohm resistor will then be dissipating about 8 milliwatts. (0.008 watts). A 3 watt resistor won't even start to get warm. The general rule of thumb is that you select a resistor with double the expected wattage next-size-up. That is, if your resistor is actually dissipating 1 watt, double is 2 watts, next size up is 3 watts. However, to be dissipating 1 watt, the current through the resistor is going to be about 100 mA, which is WAY THE HELL more than I really think you are dissipating. That's why I asked you to check the current through the resistor (or the voltage across it, same thing) so we could see what the resistor was REALLY dissipating. You'd probably want to make this measurement fairly close to the top end of the scale where the current is most probably the greatest. Some posters have postulated that a larger wattage resistor will be more resistant to vibration and the like. I respectfully disagree. I'd much rather something about the size and mass of a toothpick than size and mass of a large ball bearing bouncing around. If we can get a handle on exactly how much power this sucker is dissipating, we may be able to do a Rat Shack fix for a buck or so. Keep me posted. Jim "Jim Burns" wrote in message ... Thanks Jim, I appreciate the link. Not having a background in electronics, what ultimate difference would a resistor of higher wattage rating have on the circuit, the gauge, or the probe? If the circuit is only drawing mA's, 1) are there "smaller" mA rated 82ohm resistors available or 2) with a mA rated resistor would the required ohm rating change? Forgive my ignorance regarding resistors, I basically understand what they do, but do not know the implications of the sizes/capacities. I'm just looking for a way to get out of several hours of tedious PITA work with my upper torso stuffed up underneath our panel. |
Old CHT probe replacement | Frank Ch. Eigler | Owning | 3 | August 31st 05 03:22 PM |
T.E. Probe Question | KP | Soaring | 2 | July 27th 05 02:58 PM |
Replacement JPI EGT probe | Robert M. Gary | Piloting | 4 | July 16th 05 02:28 AM |
Cleaning a 3-way TE probe | Jack Glendening | Soaring | 37 | November 5th 03 06:45 PM |
Broken line to Oil Temperature Probe, Repairable? | rkane33 | Owning | 2 | July 25th 03 03:19 AM |
