Kevin Horton wrote snip
pacflyer - which aircraft do you have your StormScope or StrikeFinder time on? Have you flown any GA radars? snip Kev, For me it's been all Wx Radar. BE-18 had an old-timey (RCA I believe?) set that was broken most all of the time. All of my other experience has been with numerous different commercial sets in jets: Bendix, Collins, RCA, etc. Lots of the guys I flew with at four airlines however, flew Stormscope stuff in GA. None of them has ever said anything good about it. In fact most of them say these exact words when asked: "it's better than nothing." Unquote. After an old hand like me teaches em how to set the gain manually and put a little ground clutter out there with the tilt for insurance they don't want to go back. Approaching a line? Use the tilt formula to calculate if the cell is above your altitude or not. Doubt you can tell much about vertical development with a Stormsope but then I've never used one; been spoiled with good radar. The newer Collins sets have auto-tilt and gggreat turb modes (magenta) but no one has been able to explain to me how this feature works even in clear air. It's amazing. And I'm a guy who used to fly into IAH every night in occluded fronts, windshear, downbursts etc on an old Bendix green screen (and I thought that was great.) How's the weather? We used to say: "what difference does it make? we're going anyway!" snip .. If the water is coming down strong enough, it will stop the radar from seeing anything further out in that direction. So you may see a glob of red, with green and black on the other side, but it is only green or black because the radar signal isn't punching through to there. Yes indeed. This is called attenuation (actually the radar probably does make it to the curved edges of the drops in your downburst or strong cell, its just that the energy is absorbed or deflected and never makes it back to the aircrafts' antenna receiver dish.) This killed the crew and occupants of a NWA flight one night. They punched into a level five I think we would call that today. This was a famous accident in the industry and one night I was jumpseating on AWA to JFK and we watched another flight below us try to do the same thing over Kansas City. A huge discharge that blinded us for a second convinced him to turn around. He kept arguing with ATC about how good it looked straight ahead. We were all laughing our asses off when we saw him do the 180! The StormScope stuff, in theory, should keep you out of the really bad stuff, as any CB should be producing lightening. It won't keep you out of TCUs, but they shouldn't kill you, although they may scare the hell out of you. I've seen quite a bit of variation in performance on different StormScope installations. One aircraft I flew (TB-21) had a StormScope installation that worked extremely well. The C550s that I fly with StormScope seem to work much less well. I suspect the technology is very sensitive to where the antenna is located, how well everything is grounded, and how much electrical noise the aircraft produces. YMMV. With weather radar, I suspect there is probably less installation to installation difference in performance, for the same model unit and same antenna. Obviously more expensive units with bigger antennae and more power will work better than the cheaper GA stuff. Radome cleanliness is important with big commercial units. I've lost ability to paint targets due to extreme ice built up on the nose in flight, and due to peeling paint. Peeling paint is the worst. You constantly are dodging phantom cells that aren't there. We cringe at the thought of no radar, but truthfully, a lot of the old guys flew Connies without any and weren't concerned about it. They were *always* in the weather they told me. Of course several disappeared and were never found. Ahhh ... constant turbulence that spills my coffie on my white shirt and the faint smell of burning glycol in the packs and the acrid odor of negative ions at high altitude, combined with bone-dry eyeballs and radioactive, infectious, packages just inches from the meal storage box.... makes me want to be scud-running in my little airplane with a strike finder! Stay away from Freddie Kilowatt! pacplyer - out |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 9th 04 03:47 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 04 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 04 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
