Maule Driver wrote:
Further testing shows the floor doesn't work. Back to the tubing crotch. Try putting it high behind the rear bulkhead. You'll be able to get it out easily, but it might work better there. Michelle has her ELT back there. If it works well, you could screw a metal plate onto the rear bulkhead (above the removable part) and attach it to that with the magnet. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Well, I ended up with it in the overhead crotch. I might stay with that
awhile until I figure out how much I'll want to remove it for land use. Turns out that it can easily and securely be popped in and out right thru one of the the headliner zippers and I just let the cable hang. OK for now. I'll have to write a trip report for the weekend. What a machine!! George Patterson wrote: Maule Driver wrote: Further testing shows the floor doesn't work. Back to the tubing crotch. Try putting it high behind the rear bulkhead. You'll be able to get it out easily, but it might work better there. Michelle has her ELT back there. If it works well, you could screw a metal plate onto the rear bulkhead (above the removable part) and attach it to that with the magnet. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Maule Driver wrote:
Well, I ended up with it in the overhead crotch. I might stay with that awhile until I figure out how much I'll want to remove it for land use. You might consider buying another antenna for land use. IIRC, the price is about $240. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
In article 8zjTe.15758$aG.13842@trndny01,
George Patterson wrote: Maule Driver wrote: Well, I ended up with it in the overhead crotch. I might stay with that awhile until I figure out how much I'll want to remove it for land use. You might consider buying another antenna for land use. IIRC, the price is about $240. There's a catch: The 396 XM antenna is also the XM receiver. XM will only allow one receiver to be assigned to each subscription. JKG |
I guessed that was the case.
Jonathan Goodish wrote: There's a catch: The 396 XM antenna is also the XM receiver. XM will only allow one receiver to be assigned to each subscription. |
Maule Driver wrote: I guessed that was the case. Jonathan Goodish wrote: There's a catch: The 396 XM antenna is also the XM receiver. XM will only allow one receiver to be assigned to each subscription. It's a shame that they couldn't get the GPS antenna in the same package with the XM antenna/receiver. It seems to me that unless you mount it on the yoke and keep it there (i.e. don't move it to your lap), you're likely to lose GPS sats unless you're using the external GPS antenna--which is another wire. Same story in the car. One question: Do you guys protect the screen lens with anything, like a PDA screen protector? Or is it pretty resistant to scratching? JKG |
Jonathan Goodish wrote: In article , Maule Driver wrote: I guessed that was the case. Jonathan Goodish wrote: There's a catch: The 396 XM antenna is also the XM receiver. XM will only allow one receiver to be assigned to each subscription. It's a shame that they couldn't get the GPS antenna in the same package with the XM antenna/receiver. It seems to me that unless you mount it on the yoke and keep it there (i.e. don't move it to your lap), you're likely to lose GPS sats unless you're using the external GPS antenna--which is another wire. Same story in the car. One question: Do you guys protect the screen lens with anything, like a PDA screen protector? Or is it pretty resistant to scratching? I do on my 195. |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
