O. Sami Saydjari wrote: Jeff, I have "narrowed it down" to three planes: 1965 Piper Comanche PA-24-260 1978 Mooney "201" M20J 1977 Piper Arrow III The Arrow doesn't get as much advantage from being complex as the other two planes. If you want something in the Cherokee series the 235s are faster and carry more without the added maintenance costs of retractable gear. They're popular with flight schools, though. -- Ben Jackson http://www.ben.com/ |
Yes I think the retractable gear does help alot, at 150 kts, with only 200
HP, is pretty good. You cant put a turbo arrow with the normally aspirated ones. Their performance is alot different. the cherokee 235 is a 235 hp plane, is slower then a Turbo Arrow, but about the same as a normally aspirated Arrow and has a lower ceiling then a Turbo Arrow. you can see some performance specs for a bunch of planes here http://www.ferryflight.info/perfs.html they have speed and range for most planes by the look of it. Jeff Ben Jackson wrote: The Arrow doesn't get as much advantage from being complex as the other two planes. If you want something in the Cherokee series the 235s are faster and carry more without the added maintenance costs of retractable gear. They're popular with flight schools, though. -- Ben Jackson http://www.ben.com/ |
Jeff wrote: Yes I think the retractable gear does help alot, at 150 kts, with only 200 HP, is pretty good. You cant put a turbo arrow with the normally aspirated ones. He didn't say Turbo Arrow III, did he? Or did all Arrow IIIs come with TIO-360s? If he's talking turbo that makes some sense, since the numbers are similar to the Comanche and the M20J. The big difference will be that the optimal altitudes will be higher in the turbo. That's a win if you're in Colorado but probably a lose on the coasts or in the midwest. The Comanche peaks at ~160KTAS @ 7000' @ 75%, like all non-turbos it can't hold 75% beyond that, dropping back to ~155KTAS @ 10000 @ 65%. The Turbo Arrow probably doesn't even hit its peak until the low teens, but I don't have a chart for it. -- Ben Jackson http://www.ben.com/ |
I had mentioned turbo arrow, he mentioned arrow, Alot of people confuse the
two, putting them in the same catagory not knowing there is a difference. My personal opinion is that a comanche is still the best plane for the money for useful load and speed. the only problems with them is the avionics are usually outdated, avionics are so expensive alot of people dont upgrade them. My wife only let me upgrade to our current plane if I promised to get one with airconditioning, so the comanche was out for us. Also the turbo arrows I looked at all seemed to have more options in them then most other planes in the same catagory., ie, storm scope, airconditioning, HSI, auto pilot. The main problem with a turbo arrow for me, is the rate of climb. you only use max horse power for take off, then at about 1000 ft you reduce power to cruise climb which is 75% power. and 75% power at 104 kts only gets you about 500 FPM. Its kinda a trade off, turbo's are good if you consistantly fly higher, if you like lower then no need to really get it, unless you want the extra speed it has, and for the price, its a pretty good deal. At 10,000-12,000 ft your hanging with bigger/faster planes like the bonanza. Ben Jackson wrote: He didn't say Turbo Arrow III, did he? Or did all Arrow IIIs come with TIO-360s? If he's talking turbo that makes some sense, since the numbers are similar to the Comanche and the M20J. The big difference will be that the optimal altitudes will be higher in the turbo. That's a win if you're in Colorado but probably a lose on the coasts or in the midwest. The Comanche peaks at ~160KTAS @ 7000' @ 75%, like all non-turbos it can't hold 75% beyond that, dropping back to ~155KTAS @ 10000 @ 65%. The Turbo Arrow probably doesn't even hit its peak until the low teens, but I don't have a chart for it. -- Ben Jackson http://www.ben.com/ |
I love my turbo. It is of course a waste of time/money/etc at lowish
altitudes, say below 8000'. But the freedom to climb at keep on climbing, not to mention high-performance take-off without having to worry about density altitude (well, not so much anyway) is enormous. I can climb to FL200 at a steady 500 fpm - the plane would probably go quite a lot higher although it is not certificated to do so and I haven't tried it. On long journeys going up high is a real bonus, especially over unfriendly terrain. John "Jeff" wrote in message ... I had mentioned turbo arrow, he mentioned arrow, Alot of people confuse the two, putting them in the same catagory not knowing there is a difference. My personal opinion is that a comanche is still the best plane for the money for useful load and speed. the only problems with them is the avionics are usually outdated, avionics are so expensive alot of people dont upgrade them. My wife only let me upgrade to our current plane if I promised to get one with airconditioning, so the comanche was out for us. Also the turbo arrows I looked at all seemed to have more options in them then most other planes in the same catagory., ie, storm scope, airconditioning, HSI, auto pilot. The main problem with a turbo arrow for me, is the rate of climb. you only use max horse power for take off, then at about 1000 ft you reduce power to cruise climb which is 75% power. and 75% power at 104 kts only gets you about 500 FPM. Its kinda a trade off, turbo's are good if you consistantly fly higher, if you like lower then no need to really get it, unless you want the extra speed it has, and for the price, its a pretty good deal. At 10,000-12,000 ft your hanging with bigger/faster planes like the bonanza. Ben Jackson wrote: He didn't say Turbo Arrow III, did he? Or did all Arrow IIIs come with TIO-360s? If he's talking turbo that makes some sense, since the numbers are similar to the Comanche and the M20J. The big difference will be that the optimal altitudes will be higher in the turbo. That's a win if you're in Colorado but probably a lose on the coasts or in the midwest. The Comanche peaks at ~160KTAS @ 7000' @ 75%, like all non-turbos it can't hold 75% beyond that, dropping back to ~155KTAS @ 10000 @ 65%. The Turbo Arrow probably doesn't even hit its peak until the low teens, but I don't have a chart for it. -- Ben Jackson http://www.ben.com/ |
John
what kind of plane do you have? Jeff John Harper wrote: I love my turbo. It is of course a waste of time/money/etc at lowish altitudes, say below 8000'. But the freedom to climb at keep on climbing, not to mention high-performance take-off without having to worry about density altitude (well, not so much anyway) is enormous. I can climb to FL200 at a steady 500 fpm - the plane would probably go quite a lot higher although it is not certificated to do so and I haven't tried it. On long journeys going up high is a real bonus, especially over unfriendly terrain. John |
A 1980 TR182 (turbo, retractable) - useful load ~1150 lbs,
carries four adults and baggage plus enough fuel for 3.5hrs with reserves, or two people with fuel for 5.5hrs with reserves. Cruise at 160 at 10k, 170 in the low FLs. Rock solid flying. 14 gph at cruise. And if you practice plenty of landings, those big biceps will look great on the beach. (About the only, very minor, drawback of the plane is that it takes quite a lot of heft for pitch control. Trim is most definitely your friend). John "Jeff" wrote in message ... John what kind of plane do you have? Jeff John Harper wrote: I love my turbo. It is of course a waste of time/money/etc at lowish altitudes, say below 8000'. But the freedom to climb at keep on climbing, not to mention high-performance take-off without having to worry about density altitude (well, not so much anyway) is enormous. I can climb to FL200 at a steady 500 fpm - the plane would probably go quite a lot higher although it is not certificated to do so and I haven't tried it. On long journeys going up high is a real bonus, especially over unfriendly terrain. John |
John Harper wrote:
: I love my turbo. It is of course a waste of time/money/etc at lowish : altitudes, say below 8000'. But the freedom to climb at keep on climbing, : not to mention high-performance take-off without having to worry : about density altitude (well, not so much anyway) is enormous. : I can climb to FL200 at a steady 500 fpm - the plane would probably : go quite a lot higher although it is not certificated to do so and I haven't : tried it. On long journeys going up high is a real bonus, especially over : unfriendly terrain. A non-turbo Comanche-260 will pretty much hold 500 fpm up to higher than you can fly without oxygen. Unless you go full-tilt into high altitude with O2, etc, a Comanche-260 seems to outperform a turbo Arrow in just about every respect. It also doesn't have the drawback of the extremely abused TIO-360 Continental in the mid 70's Turbo Arrow. My mechanic just bought one of those, and all I can say is that he's comfortable with the twitchiness of that engine. Something to be said for simplicity... either normally-aspirated, big-bore, or at most a turbo-normalized engine. YMMV... ![]() -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Vendor recomendation: Stark Avionics | Ron | Home Built | 2 | December 8th 04 05:25 PM |
Real World test bed for avionics - Megawatts at Delano | MikeremlaP | Home Built | 0 | June 2nd 04 04:24 AM |
hardware to mount avionics trays | Matthew M. Jurotich | Home Built | 1 | November 17th 03 10:56 PM |
Avionics ? | Hankal | Instrument Flight Rules | 5 | August 25th 03 06:06 PM |
Avionics Swap Group | Jim Weir | Home Built | 3 | July 7th 03 02:27 PM |
