But it does sound like he may be running too lean based on the no RPM rise
reducing the mixture from full rich. If that is the case, I would suspect a miss-adjusted carb or an intake manifold leak. "tony roberts" wrote in message news:nospam-97F34F.08333904092005@shawnews... Hi I have a newly rebuilt 0300-D. It is running hot - at OAT 93F, 2 cylinders are exceeding 400F on climbout and oil exceeds 200F. (BUT EGT's are perfect - less than 45F spread on my EI Monitor) On runup, no rise in RPM prior to drop on leaning! All baffling is brand new and installed correctly. I have been told that I need to increase fuel flow to improve cooling. I don't like going to my A&E without knowing what needs doing, why and how (it's a long story ![]() So - how do I increase fuelflow on my engine? Also - Cylinder 5 is too cool - running less than 300F CHT - which means it isn't scavenging lead - a recipe for sticking valves. I have been told it's because it is out front - but so is cyl 6 and that is one of the hottest. I am running TCP in the 100ll and Avblend in the oil - the engine is smooth as silk and has 30 hours on it. All suggestions highly appreciated. TIA Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
Advice and experts with 400 series Cessnas (414 and 421), purchase and training | [email protected] | Owning | 36 | January 9th 05 02:32 AM |
Need advice on handling airplane damage | GE | Owning | 24 | November 11th 04 01:16 AM |
boot camp advice | jameson | Military Aviation | 17 | July 22nd 04 05:12 AM |
Cirrus SR22 Purchase advice needed. | Dennis | Owning | 170 | May 19th 04 04:44 PM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
