O2 safe level?
Old September 5th 05, 06:25 PM
Paul kgyy
Default O2 safe level?
I acquired a Nonin O2 monitor a while back and Saturday took it out for
a test ride. I'm 68, mild heart disease, annual special issue medical,
exercise regularly.
With regular deep breathing, I was able to retain 90% or more O2 level
as indicated by the monitor up to 13,500, and felt fine. Given that
one of the early symptoms of hypoxia is euphoria, however, I'd
appreciate if any of you who have tested this stuff would share what
you know about where hypoxia begins for most people?
Old September 6th 05, 12:01 AM
Dave S
In persons without chronic respiratory disease, in healthcare settings
we aim to keep oxygen saturations above 90-90%.
The oxygen content of the blood drops sharply below sat's of about 90%,
so the difference between 90% and 88% is greater than 92% and 90%.
You would be best off to use oxygen for flights in that area.
Dave
exercise regularly.
Old September 6th 05, 08:36 PM
Paul kgyy
Thanks, Dave. I just read the directions that came with the monitor
(always read the directions LAST :-() and that says to use 90% of your
"customary" level. e.g. people who live at 5000 feet don't normally
show 100% but have developed tolerance so 85-86% is probably OK if your
normal level is 95%.
Old September 7th 05, 12:09 AM
David Rind
That's probably not a very good plan. Most people don't show 100% at sea
level, and if your usual resting O2 saturation is 95% at sea level, you
still don't want to drop below 90% in the air for the reason that Dave
S. mentioned -- the oxygen content of the blood drops off rapidly below
a saturation of 90%.
David Rind
Old September 7th 05, 03:55 AM
Mike Rapoport
"Paul kgyy" wrote in message
When mountaineering we normally see resting numbers in the high 80s when
first arriving at a new altitude, this usually goes to the low 90s within
two days. Most people are not feeling very well in the low 80s. I have
never used an oximeter in an airplane but I imagine that it would be about
the same..
Mike
MU-2
Old September 7th 05, 04:32 AM
Mortimer Schnerd, RN
We will routinely put anybody with an SaO2 of less than 90% on oxygen in the
hospital where I work. I generally run around 95% myself on room air.
VE
Old September 7th 05, 08:37 AM
Stefan
What you do in the hospital is one thing, what you need to be able to
safely fly is an entirely different thing. In our glider club, we have
equipped all gliders with an EDS pulse demand oxygen system. We think we
have been flying noticeably better since we've routinely used it as low
as 7000ft and certainily are less tired in the evening.
Stefan
Old September 7th 05, 12:08 PM
I only mention it (90%) as a reference to what physicians consider minimally
acceptable for folks basically at sea level (~700' msl). I recognize that our
needs as pilots are different in that we generally do nothing more physical than
sit on our butts and push buttons. We do need a clear head though....
Above 10,000 feet I get a momentary twinge of lightheadedness if I cough. I
can't really define any other obvious change though. I've never explored higher
than 12,000 feet without pressurization so I can't say how rapidly I'd fall
apart as I go higher.
VE
Old September 7th 05, 01:11 PM
john smith
What do you do in the evenings that you would not be too tired to do?
slow roll in a super decathlon Nobody Aerobatics 4 August 24th 05 02:36 AM
Displaced AFSS "controllers" heading for BIL and GRB Chip Jones Instrument Flight Rules 12 April 10th 05 09:22 PM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 08:08 AM
