![]() I was able to climb above it and it was gone fairly quickly, In freezing rain, there has to be warmer air above, with warmer water - the source of the rain that then freezes when it falls through colder air below. That helps remove ice. Though depending on conditions, that warmer water may not be reachable. Even if climbing wouldn't have removed it, can't you just turn around into the warmer air? Maybe. Probably. But if conditions are getting worse all over (night is falling...) there may no longer be warmer air behind you. Interestingly enough, while you say the FAA considers forecast icing = known icing, it would seem that at least Richard L. Collins of Sporty's disagrees. Many people disagree. But they are not the ones that can pull your certificate. Then he spends a fair amount of time explaining the characteristics of icing, its relationship to Low pressure and fronts, and escape tactics... This would strongly imply that at least some pilots fly into forecast icing conditions, regardless of the legalities... Knowing about icing (beyond "Danger Will Robinson") is a good thing - a necessary thing. Forecast or not, pilots will end up in ice and need to know what to do (and what not to do) to extricate themselves before they have gone too far the wrong way. Jose -- (for Email, make the obvious changes in my address) |
