Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Converting non-US certificate to US
Old September 8th 05, 09:41 PM
Roy Smith
Default Converting non-US certificate to US
I've been asked to investigate, on behalf of some applicants to my
flying club, the procedure to take a non-US pilot certificate to a US
one. I got some good info from AOPA, but if there's anybody who's
actually been through the process and would be willing to share the
experience, I'd appreciate hearing from you.
Old September 12th 05, 02:34 AM
Magic Fingers
I'm doing it right now. Applicant holds the equivalent of PPL from the JAA.
He's a 30 hour VFR only pilot.
Spoke with two local DPEs. Both said to prep him to the PPL PTS, as that's
what they have to test him to. No shortcuts. Oral and flight test as if he
was a low-time student pilot applying for his first ticket.
Simple. No muss, no fuss.
Pat Brown
CFII
"Roy Smith" wrote in message
Old September 12th 05, 03:06 AM
Magic Fingers
Oops....
TYPO. He's a 300 hour PPL!!!
Sorry.
PB
"Magic Fingers" wrote in message
JAA. He's a 30 hour VFR only pilot.
he was a low-time student pilot applying for his first ticket.
Pat Brown
CFII
Old September 12th 05, 08:46 AM
Thomas Borchert
Roy,
one.
Well, is you aim a US certificate based on a valid foreign certificate
or do you want to end up with a full US certificate independent of the
foreign license?
The FAA website spells out the details, but basically for the former,
you need to apply to the FAA in advance, which will check if you hold a
valid foreign certificate. After that, go to an FSDO and collect the US
certificate. After that, do a flight review and you're good to go.
For the latter, you need to apply for training with the TSA first.
Then, you basically need to go through the full training and all tests
- except that all training received for your foreign certificate
counts. In essence, you might end up needing to do only the 3 hours
required in preparation for the test.
Thomas Borchert (EDDH)
Old September 12th 05, 02:04 PM
Roy Smith
Thomas Borchert wrote:
Roy,
one.
foreign license?
I don't know exactly. The former sounds simpler. Are there advantages to
the latter?
Old September 12th 05, 04:18 PM
Thomas Borchert
Roy,
the latter?
It IS simpler. WAY simpler. And I would recommend to go that way for
occasional flying in the US. Mind you, the certificate holder will have
to do a full flight review, often forgotten by FBOs renting to
foreigners. If s/he is not familiar with US airspace, regulations and
procedures (radio work, above all), and the CFI giving the review is
halfway responsible, this will take more than an hour ground school and
an hour in the air.
The advantage to the "true" US certificate is that you can build
ratings and new certificates according to US standards on it. Also,
should your underlying foreign license become invalid for some reason,
the US certificate based on it would become invalid, too. One very
important possibility for that scenario lies in the extremely strict
medical requirements for private pilots in some European countries,
e.g. Germany. It's quite easy for a pilot to have his German medical
declined on a condition that would be perfectly ok in the US. Allowable
uncorrected vision, for example, is limited in Germany, it isn't in the
US.
Old September 12th 05, 10:40 PM
Sylvain
foreign license?
the latter?
yes and no. it depends on the country that issued the
license upon which the US certificate is based; for
instance, I got my first US certificate under 61.75
based on the old style (pre-JAR) British PPL(A); in
this case, it was actually more advantageous for me
to do so than to get a 'real' FAA certificate; for
one thing, the British PPL(A) did not expire (just
like the US certificate, i.e., the piece of
paper does not expire); and that's important, because
61.75 says that the US certificate is valid as long as
the foreign license upon which it is based remains valid
(unless it is explicitly revoked or surrendered);
Moreover, at the time, my British Class-III medical
was valid 5 years :-) -- so all in all, it was simpler
at the time to stick with my 61.75 based certificate
nowadays however, it is my understanding that the new
JAR licenses do have an expiration date on it (I haven't
bothered yet to exchange my British PPL(A) for one -- but
I understand that folks with a German PPL also had the
same problem, i.e., expiration date on the license); and
it becomes a pain in the neck since you have to keep
not just one, but two civil aviation authorities
happy.
Now, if someone already has a foreign private license;
I reckon the best bet would be to i) apply for a US
certificate based on the foreign license under 61.75,
even though it has become more complicated and requires
that the country of origin certifies your credentials;
and ii) prepare for the commercial ticket; i.e., if you
must prepare for a written exam and checkride, might
as well go for the commercial for just a little bit
-- not that much -- more effort.
that's what I did actually (I still keep my private
certificate based on the foreign license because it
still has my glider rating on it; I should eventually go
spend a couple of weeks at a place like Minden and
get the commercial and be done with it :-)
--Sylvain
Old September 12th 05, 10:44 PM
Sylvain
ratings
ok, may be this one changed, but I was able at the time to
add the US Instrument Rating on my private certificate based
on a foreign license.
US.
indeed. but some foreign licenses were valid -- as far as 61.75 was
concerned -- indefinitely, regardless of you having the corresponding
foreign medical (and/or maintained the foreign currency
requirements); that was the case with the old British PPL(A).
--Sylvain
Old September 28th 05, 08:47 AM
Thomas Borchert
Peter,
Not quite sure where I was wrong, but alas...
Very few pilots will have a
condition which allows them to fail JAA and then pass FAA.
The vision thing I mentioned is a very real problem herein Germany. Be
aware that there is NO such thing as a JAA medical, really. The German
JAA medical requirements differ vastly from the British, for example.
My example with regard to vision is a good one for that. Now, I could
go to the UK every time I need a medical for my German JAA license (I
think), but that's not very practical.
Question about medical certificate and Zyban... [email protected] Piloting 27 July 28th 05 03:57 PM
faa home study graduation certificate Falky foo Piloting 19 February 10th 05 11:38 PM
Time for certificate issuance? Jeremy Lew Instrument Flight Rules 5 July 21st 04 04:11 PM
PA-32 on Experimental Certificate Mike Granby Owning 3 July 21st 04 03:04 AM
