what the heck is lift?
Old September 9th 05, 05:32 AM
Peter Duniho
"buttman" wrote in message
So whats the deal here? Are we just thinking of two diffrent concepts?
Your instructor is wrong, and should not be instructing.
In straight and level flight, lift equals weight. Unless your weight
changes, lift does not change, regardless of airspeed. What *can* change is
the lift coefficient, which is determined by the angle of attack. But lift
itself remains static.
Pete
Old September 9th 05, 12:12 PM
Roger Long
Lift in a fully developed spin or steady sinking mush is also exactly
the same as in level flight.
Roger Long
Old September 9th 05, 02:37 PM
Jimbob
On Fri, 09 Sep 2005 11:12:36 GMT, "Roger Long"
Hmm. If lift was equal to weight in level flight the forces are
equal, thus no change in height.
How do you reconcile this with a mush or spin? Height is changing,
thus left is less than weight.
http://www.unconventional-wisdom.org
Old September 9th 05, 04:41 PM
Hilton
Not even close!
Hilton
Old September 9th 05, 06:51 PM
Peter Duniho
"Hilton" wrote in message
. net...
Not even close!
He's quite close. See Todd' post.
I wrote "straight and level flight" simply because that was the scenario
being discussed in the original post. But any unaccelerated flight means
lift equals weight, and that includes the "fully developed spin" and "steady
sinking mush" Roger described.
Pete
Old September 9th 05, 07:30 PM
Larry Dighera
On Fri, 9 Sep 2005 10:51:23 -0700, "Peter Duniho"
wrote in
sinking mush"
Isn't there acceleration in a sinking mush? If the aircraft is
descending, does lift equal weight?
Old September 9th 05, 07:36 PM
Hilton
Peter wrote:
Not even close!
"steady
Todd's reply to this clearly shows why Roger's statement is wrong. A large
percentage of the upward force in a spin is drag. The extreme case is a
parachutist coming straight down in one of those old round parachutes. In
this case, the 'aircraft' has zero lift and DRAG == WEIGHT.
Lift, drag, and thrust can be pointed in any direction; the only constant is
weight which always points towards the center of the earth.
Hilton
Old September 9th 05, 10:47 PM
Peter Duniho
ink.net...
No, it doesn't. See my reply to Todd and Stefan's reply here to understand
what we are all talking about.
Old September 10th 05, 01:37 AM
Hilton
understand
You wrote "Had his definition of lift been correct, he would have been
exactly correct." Ummm, OK. But lift is well-defined and it is not
defined as the force that opposes weight. So, you can redefine whatever you
want, doesn't make it right.
Hilton
Old September 10th 05, 03:13 PM
Roger Long
The distinction is really a thought convenience to help us talk about
what is going on and not a real physical difference. Lift is really
drag directed upwards.
Roger Long
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
New theory of flight released Sept 2004 Mark Oliver Piloting 70 October 10th 04 10:50 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 10:55 PM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 08:52 PM
