On Fri, 09 Sep 2005 10:59:00 -0400, T o d d P a t t i s t
wrote: "Brian" wrote: Generally speaking lift = AOA * Airspeed. Not quite. Generally speaking lift is proportional to AOA * (Airspeed squared). Except when accerlating or decelerating up or down (i.e Beginning or ending a climb or descent) the lift = weight of the airplane. This is close and is often a reasonable approximation, so I'm not really disagreeing, just expanding. However, lift is actually defined as a force perpendicular to the flight path, so in climbs, some weight is supported by thrust, and in descents, some weight is supported by drag. Lift is slightly reduced in both cases. In a somewhat more extreme example, when I pull my 400 hp Sukhoi into a nearly vertical attitude, the rate of climb decreases to essentially zero, i.e., the airplane hovers. In this case, the wings are providing essentially no lift and the airplane is being supported by almost totally by thrust. Actually, you should imagine Sean Tucker doing this as I don't do it all that well. ;-) Klein |
Klein wrote:
In a somewhat more extreme example, when I pull my 400 hp Sukhoi into a nearly vertical attitude, the rate of climb decreases to essentially zero, i.e., the airplane hovers. In this case, the wings are providing essentially no lift and the airplane is being supported by almost totally by thrust. In this situation, you might call that trust lift produced by the propellor blades. Stefan |
"Stefan" wrote in message
... In this situation, you might call that trust lift produced by the propellor blades. You might. But then you get into trouble in straight and level flight when those propeller blades are still producing that lift. Then the total lift greatly exceeds the airplane's weight. ![]() Pete |
a nearly vertical attitude, the rate of climb decreases to essentially zero, i.e., the airplane hovers. In this case, the wings are providing essentially no lift and the airplane is being supported by almost totally by thrust. Actually, you should imagine Sean Tucker doing this as I don't do it all that well. ;-) Still the same Principle, Your just transfering your lift from the Fixed wing the Rotating Wing (the Propeller) Brian |
Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 07:50 PM |
Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 04:08 PM |
New theory of flight released Sept 2004 | Mark Oliver | Piloting | 70 | October 10th 04 10:50 PM |
Lift and Angle of Attack | Peter Duniho | Simulators | 9 | October 2nd 03 10:55 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
